Is my stepper gone?
I am trying to run a stepper with a Pololu driver and cannot, even though I have tried quite a few wiring combinations. Moreover, I have noticed that the resistance of the two coils is different: on one there is 3.0 om, on the other 1.6. Does that mean that the stepper is faulty? It might have been overheated...
Post a link to the datasheet for your stepper motor.
The Pololu website has very clear wiring diagrams.
This Simple Stepper Program works with my Pololu A4988s
...R
Stepper Motor Basics
The datasheet is here.
It is 10PU-M204-G2ST with four wire connector.
Jabberwock:
That shows the winding resistance at 10 ohms, and yours are much less. Combined with the fact that it doesn't work seems to bode ill. It would seems that you have insulation failure (shorting winding turns together) caused by the overheating.
I guess that is it then... :frowning: Thanks for the explanations!
At that stage I would open it up and have a look inside - if only for the destructive explorative fun :slight_smile:
...R
Is your stepper 6-wire like that datasheet says? If so don't take it apart, just figure
out the windings properly - to use as bipolar identify the centre-taps and don't use them.
Motors always come in a variety of different windings, its possible this is the one in the
datasheet except its wound for 1.5+1.5 ohm centre-tapped
