I've had a WiFi1010 with a 1.8" TFT Display(ST7735) running as a clock on my desk for last couple months. Today I thought I would add the ability to display weather info from Open Weather Map. This is where my issue began.
I had been working on it for a bit and had done several successful uploads already when on the last upload it freaked, threw a bunch of errors and failed to upload. Wish I would of payed more attention to what those errors were because I never saw them again.
After that first failed upload when I try to upload to it, it just freezes here:
Linking everything together...
"C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.12\\variants\\mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.elf" "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009\\sketch\\Blink.ino.cpp.o" "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/..\\arduino_cache_734026\\core\\core_arduino_samd_mkrwifi1010_53d0a7517f33b85c1aedd7227a541402.a" -Wl,--end-group
"C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.elf" "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.bin"
"C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.elf" "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.hex"
"C:\\Users\\HuhDO\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\HuhDO\\AppData\\Local\\Temp\\arduino_build_433009/Blink.ino.elf"
Sketch uses 12200 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 2996 bytes (9%) of dynamic memory, leaving 29772 bytes for local variables. Maximum is 32768 bytes.
Forcing reset using 1200bps open/close on port COM4
Which is where it is finished compiling and starts looking for a port to upload to. In the IDE in the tools tab the port shows as "COM4(Arduino MKR WiFi1010)" (as does device manager) which is correct for this board. clicking the compile button is the only way to unfreeze it.
If I restart the IDE after a failed upload it will take a much longer time to open back up. If I restart windows 10 with the board plugged in it will tell me that the USB device failed and it will not show up in Device Manager until I unplug it and plug it back in.
New Info:
While writing this post I left the IDE frozen still trying to upload, after about 20 minutes it did finish with this error:
PORTS {COM1, COM4, } / {COM1, COM4, } => {}
Uploading using selected port: COM4
C:\Users\HuhDO\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM4 -U true -i -e -w -v C:\Users\HuhDO\AppData\Local\Temp\arduino_build_433009/Blink.ino.bin -R
An error occurred while uploading the sketch
So no indication what the error is.
One more thing, I have a second Wifi1010 that still uploads perfectly.
EDIT: I just remembered that these boards switch to COM6 during the upload(confirmed using second WiFi1010) which this board is not doing now.
