Is necessary burn bootloader on AT91SAM3X8E?
Hi! We are thinking to use AT91SAM3X8E, before we were using ATMEGA328P, as you know, on 328P is necessary burn bootloader when you buy the micro for to can upload a sketch. Is necessary in case of AT91SAM3X8E the same process? i saw in other forums that is not necessary because is burned in factory.
Can you validate that info?
Thanks a lot, waiting your answer.
The Arduino "Burn Bootloader" command usually does two things:
  1. Sets the chip configuration ("Fuses", on an AVR) appropriately for working with the Arduino environment. This includes the fuses that say whether a bootloader is present, and how big it is, but it also includes other details, like memory protection and clock configuration.
  2. Loads the bootlloader into the appropriate spot in flash memory.
Now, the SAM3X8E has a bootloader in ROM, so there is no need for the 2nd function (and consequently, I don't believe that the "burn bootloader" would actually load any code.)
The SAM3 DOES have a few "configuration" bits (GPNVM) that you'll need to make sure are set correctly for your application. I think that the default settings are correct for an Arduino, but ...
(incidentally, the Arduino IDE doesn't seem to support any "programmers" for the SAM3 platforms, so the "burn bootloader" operation doesn't work. If you need to make changes, you'd have to do it either programmatically or with a JTAG/SWD programmer.)
Hi westfw, thanks for your answer.
Sorry but your answer is not clear for me yet. We want to buy the chip and directly to solde and upload the sketch (with ftdi, usb-uart, etc..). Is this possible? Have we to do any process before upload the sketch?
Thanks for your time.
You have to provide the mechanism(s) for activating the bootloader that is in ROM. I think that means implementing the "erase" signal because the bootloader will run if flash is erased, but I'm not familiar with the details.
