Is noInterrupts(); needed with a volatile variable?
In the code below, in void Brew(), do I need the noInterrupts(); and interrupts(); lines? The variable FlowSensorCount is declared volatile, and an interrupt runs the code "FlowSensorCount++;"
Perhaps I need to turn off interrupts when checking that variable, or maybe not? Won't that make my flow meter miss some counts when interrupts are turned off.
// D2---FLOW SENSOR
// D3--WATER VALVE SOLENOID
#include <LED.h>
#include <Button.h>
Button startButton = Button(A5,PULLUP);
Button fullButton = Button(A2,PULLUP);
Button halfButton = Button(A0,PULLUP);
LED startLED = LED(A4);
LED fullLED = LED(A3);
LED halfLED = LED(A1);
//3 selection conditions:
const int emptyPot = 0;   //no selection made
const int fullPot = 1;    //full pot selection
const int halfPot = 2;    //half pot selection
// variables:
int potSelection = 0;     //selection starts out with nothing on power up
int fullCount = 200;     //number of pulses for a full pot of coffee
int halfCount = 100;     //number of pulses for a half pot of coffee
unsigned long lastPress;  //last time any button was pressed, for timeout
//***************setup variables***************
volatile int FlowSensorCount;  //the counter for the flow sensor
  Serial.begin(9600); //initiate serial port
  Serial.println("Bunn Coffee Water Version 1.0");
  attachInterrupt(0, CountPulse, RISING);//turn on interrupt for flow sensor on pin 2
  digitalWrite(2, HIGH);    //turn on pull up resistor for flow sensor on pin 2
  delay(200);
void CountPulse() //called from the interupt on Pin 2, from the water sensor
  FlowSensorCount++;  //increases count by 1
  updateStartLED(); //update start LED status
  if (fullButton.isPressed()){ //if the full button was pressed
    lastPress = millis(); //update the time
    Serial.println("Full Selection Button was pressed");
    fullLED.on();  //turn on full LED
    halfLED.off();   //turn off half LED
    potSelection = fullPot; //they selected a full pot
  if (halfButton.isPressed()) { //if the half button was pressed
    Serial.println("Half Selection Button was pressed");
    halfLED.on(); //turn on half LED
    fullLED.off();//turn off full LED
    potSelection = halfPot; //they selected a full pot
  if (startButton.isPressed()) { //if the startbutton was pressed
    Serial.println("Start Button was pressed");
    if (potSelection == fullPot) Brew(fullCount); //brew a full pot
    else if (potSelection == halfPot) Brew(halfCount); //brew a half pot
    else flashSelection();
  if (millis() - lastPress > 10000) { //they changed their mind?
    potSelection = emptyPot; //cancel the selection
    fullLED.off(); //turn off any LEDS
    halfLED.off(); //turn off any LEDS
    startLED.off(); //turn off any LEDS
  delay(100);
void Brew(int pulseCount){
  int solenoidPin = 3; //water valve solenoid pin
  pinMode(solenoidPin, OUTPUT); //set it as an output
  FlowSensorCount = 0; //reset sensor count
  digitalWrite(solenoidPin, HIGH);  //turn on the water valve
  while (1) {
    noInterrupts();
    if (FlowSensorCount >= pulseCount) {
      digitalWrite(solenoidPin, LOW);  //turn off the water valve
    interrupts();
void updateStartLED() {
  if (potSelection == emptyPot) return; //no selection is made so do nothing with the start LED
  unsigned long lastBlink; //last state change
  if (millis() - lastBlink > 500) { //it's time to toggle
    startLED.toggle();
void flashSelection() {
  //user pressed start before making a selection
  //flash the half and full LEDS to give them a hint on what to do!
  Serial.println("make a selection first! (Half or Full)");
  boolean state;
  halfLED.on();
  for (int i = 0; i < 10; i++) {
    state = !state; //change the LED state
    halfLED.toggle();
    fullLED.toggle();
    delay(100);
  halfLED.off();  //turn off on leaving
  fullLED.off();  //turn off on leaving
If you're touching a volatile variable bigger than a byte, you will certainly need to turn interrupts off. This is because getting the two bytes of your int is not an atomic operation, so you may get one byte loaded and have the interrupt change the value before you get the second, giving you garbage.
I'm not comfortable saying that a single byte operation would be bulletproof either, but this is because I just don't know - it may be.
To minimize the time interrupts are off, just copy the volatile variable to another variable in the critical section. Work with the copied one afterwards.
If an interrupt occurs while interrupts are off, it's queued. If it's more than one, you've missed some.
Thanks! That makes sense. Just curious, I wonder how long it takes to read the flowsensecount value? I guess the flowmeter puts out about 10 pulses per second, so that 100 ms. It probably only takes a ms or 2 to check if flowsensecount is larger than the limit.
Much much much less than that. A single instruction on the Uno takes ~65nS and that comparison probably takes less than ten instructions.
Wow!
