Well, that's the question.
I just want to use a LED as a resistor to connect a Buzzer to the Arduino tablet.
Is that possible? How many ohms will the a red LED of 2.1v effectively have?
Thanks you, all!
Thanks you, all!
No. An LED is a highly nonlinear (nonOhmic, one way conduction) device and passing too much current will destroy it.
Dude, wake up. Leds are NON- LINEAR !
Your question is absurd.
Take a look at an answer to a similar question asked by someone else:
accounting-for-led-resistance
Let's pretend you never asked that question (I won't tell if you don't) and address the question you should have asked:
"Hi, I have a buzzer rated for "X" Volts.
I have a power source of "Y" volts from [blank ].
I would like to run the buzzer but have a led turn on when the buzzer is on.
How do I do this "
Answer: The led can be placed in parallel with the buzzer with a current limiting resistor in series with the led. The resistor value is calculated as follows:
Let Vcc = Y volts
Let led forward voltage = Z volts @ 20 mA
Let buzzer voltage = X volts
RCL= (Y-Z)/0.020 A
Was this comment called for ?
Let's Google "do leds have resistance ?" and see what comes up:
Google Search: do+leds+have+resistance
Current versus voltage is a straight line for a resistor, but not at all for an LED. Because of this, you can't say that LEDs have “resistance.” Resistance is defined as the constant ratio of voltage to current in a resistive circuit element.
No..
But at low current > 5 mA they can make a fair Zener diode..
Not great tempco but tolerable for testing.. until the real part comes.
The real limit is that the Led has a limited voltage.. due to the short number of Led colors.
I have one used as the reference voltage for a variable voltag bench power supply (Red 1.8V Vref)
Doc
Thank you Guys, I am a noob in electronics.
Now I have a good direction to follow and I know what I need to read/study.
I have seen one circuit where the power LED was a functional part of the circuit. It needed a bias voltage or something and an LED was the right component for that job.
Normally you don't do this.
MorganS:
Two situations come to mind - bias voltage for an electret microphone, and bias for the base of a transistor used as a constant-current source.
Is there a current limiting resistor in there anywhere ?
raschemmel:
Using it as a "Zener" with a lower voltage than an actual Zener.
A series resistor, a parallel capacitor, and then the load resistor to the electret.
Mind you, that was when electrets required 1.7 V.
