Is possible use LCD TFT display with RFC 522, both usages the same pins.
Good Morning, i have a tft display 3,5 with Atmega 2560 and this use PIN 5 and others pins already used in the RFC 522 module, exist a "solution" to usage other pins to communication SPI from RFC 522?
Are you saying you need two SPI devices?
Just define separate CE pins.
TheMemberFormerlyKnownAsAWOL:
Yes, i have :
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 5 // Configurable, see typical pin layout above
#define SS_PIN 53 // Configurable, see typical pin layout above
But TFT already use pin 5, i can change it to any number?
And SS_PIN, i can change too?
The pins MOSI, MISO and others i did not have problems.
Yes, chip selects/slave selects can be any pins.
The SPI SS pin Must be an output for the Mega/Uno to be SPI bus master, even if you use the pin for something else.
If it becomes an Input and goes low, the Arduino will act as an SPI slave.
And for others pins? As a Miso, Mosi, is possible change too?
I guess that not possible this possible because in instance of MRFC522 we send only SS and RST in parameters.
Sorry for my bad english...
You need two separate SS pins; the one can be the existing one and the other one has to be something else. The other SPI pins can be shared.
