Is SD.begin a one-time thing??After removing card, it can't reinitialize...
this is the code
#include <LiquidCrystal.h>
#include <SD.h>
LiquidCrystal lcd(7,6,5,4,3,2);
const int analogInPin = A3;
const int lcdLed=13;
const  int runLed=24;
const int chipSelect=53;
int ledState=LOW;
File myFile;
unsigned long number;
int i;
int counter1=0;
int counter2=0;
int mmenu[10];
const int rxPin=10;
const int txPin=11;
const int byteSize=64;
bool startDataReceived=false;
bool dataAvailable=false;
bool sdInserted=false;
void setup(){
  pinMode(lcdLed,OUTPUT);
  digitalWrite(lcdLed,HIGH);
  pinMode(runLed,OUTPUT);
  pinMode(chipSelect,OUTPUT);
  lcd.begin(16,2);
  mySerial.begin(9600);
  insertCard();
void insertCard(){
  while(!SD.begin(chipSelect)){
    lcd.setCursor(2,0);
    lcd.write("Please Insert");
    lcd.setCursor(4,1);
    lcd.write("SD Card...");
    lcd.clear();
  lcd.clear();
  lcd.setCursor(1,0);
  lcd.print("Press Blinking");
  lcd.setCursor(4,1);
  lcd.print("Button...");
  while(ledState==LOW){
    ledState=HIGH;
    digitalWrite(runLed,ledState);
    ledState=LOW;
    Analogkeyinput();
    if((mmenu[0]<225&&mmenu[0]>205)){
      ledState=HIGH;
  digitalWrite(runLed,LOW);
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.write("SD Card");
  lcd.setCursor(2,1);
  lcd.write("Validating...");
  delay(5000);
  myFile=SD.open("CARDID.txt");
  if(myFile){
    char fileStr[9];
    int j;
    for(j=0;j<10;j++){
      fileStr[j]=myFile.read();
    char result[9];
    uint8_t k = 0;
    while (fileStr[k] != '\0' && k < sizeof(result) - 1){
      result[k] = fileStr[k];
      k++;
    result[k] = '\0';
    number = atol(result);
  if(number==18231801){
    myFile.close();
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.setCursor(4,1);
    lcd.write("Valid!");
  else{
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.setCursor(4,1);
    lcd.write("Invalid!");
    myFile.close();
void Analogkeyinput(){
  int Ak = analogRead(analogInPin);
  int Dk = map(Ak,0,1023,0,255);
  mmenu[0]=Dk;
void loop(){
  insertCard();
problem is after i remove the card…i can get back to blinking please inserd card…but when i reinsert the card, the please insert the card won’t blink and i get stuck with the permanent please insert card…i can’t go back to rereading the file
i’m sorry i forgot to edit some
#include <SD.h>
int ledState=LOW;
File myFile;
int i;
int counter1=0;
int counter2=0;
int mmenu[10];
const int rxPin=10;
const int txPin=11;
void setup(){
  lcd.begin(16,2);
void insertCard(){
    lcd.setCursor(2,0);
    lcd.setCursor(4,1);
    lcd.clear();
  lcd.clear();
  lcd.setCursor(1,0);
  lcd.setCursor(4,1);
    ledState=HIGH;
    ledState=LOW;
    Analogkeyinput();
      ledState=HIGH;
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.setCursor(2,1);
  delay(5000);
  if(myFile){
    char fileStr[9];
    int j;
    for(j=0;j<10;j++){
    char result[9];
    uint8_t k = 0;
      k++;
    result[k] = '\0';
    myFile.close();
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.setCursor(4,1);
  else{
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.setCursor(4,1);
    myFile.close();
  mmenu[0]=Dk;
void loop(){
  insertCard();
