I want to read the SMS using Arduino and GSM module, I want to perform conditional programming based on the received SMS.
What I found really interesting is SMS format is different if I send message from different phones.
Output of my code is
Case1:(From Smart Phone)
Mobile Number is: +919542081456
Message Text: 5+22" Hello Arduino
Case2:(From normal phone)
Mobile Number is: +919848275606
Message Text: Hello Arduino
Is it really depends on the sender mobile phone? If yes how to move further to make my code independent on the sender mobile.
My code is
//===final code
char RcvdMsg[200] = "";
int RcvdCheck = 0;
int RcvdConf = 0;
int index = 0;
int RcvdEnd = 0;
char MsgMob[15];
char MsgTxt[50];
int MsgLength = 0;
void Config() // This function is configuring our SIM900 module i.e. sending the initial AT commands
Serial.print("ATE0\r");
Response();
Serial.print("AT\r");
Response();
Serial.print("AT+CMGF=1\r");
Response();
Serial.print("AT+CNMI=1,2,0,0,0\r");
Response();
Config();
RecSMS();
void Response() // Get the Response of each AT Command
int count = 0;
while(1)
if(Serial.available())
char data =Serial.read();
if(data == 'K'){Serial.println("OK");break;}
if(data == 'R'){Serial.println("GSM Not Working");break;}
count++;
delay(10);
if(count == 1000){Serial.println("GSM not Found");break;}
void RecSMS() // Receiving the SMS and extracting the Sender Mobile number & Message Text
char data = Serial.read();
if(data == '+'){RcvdCheck = 1;}
if((data == 'C') && (RcvdCheck == 1)){RcvdCheck = 2;}
if((data == 'M') && (RcvdCheck == 2)){RcvdCheck = 3;}
if((data == 'T') && (RcvdCheck == 3)){RcvdCheck = 4;}
if(RcvdCheck == 4){RcvdConf = 1; RcvdCheck = 0;}
if(RcvdConf == 1)
if(data == '\n'){RcvdEnd++;}
if(RcvdEnd == 3){RcvdEnd = 0;}
RcvdMsg[index] = data;
index++;
if(RcvdEnd == 2){RcvdConf = 0;MsgLength = index-2;index = 0;}
if(RcvdConf == 0)
Serial.print("Mobile Number is: ");
for(int x = 4;x < 17;x++)
MsgMob[x-4] = RcvdMsg[x];
Serial.print(MsgMob[x-4]);
Serial.print("Message Text: ");
for(int x = 46; x < MsgLength; x++)
MsgTxt[x-46] = RcvdMsg[x];
Serial.print(MsgTxt[x-46]);
//****Resetting all the variables*****//
//RcvdMsg[200]={0};
RcvdCheck = 0;
RcvdConf = 0;
index = 0;
RcvdEnd = 0;
MsgMob[15];
MsgTxt[50];
MsgLength = 0;
Serial.flush();
