I consider this to be strange behavior if not simply erroneous. Either something is wrong with the core programming, the ESP32 S3 chip itself, or I am completely batty (the latter having already been government certified).
This program:
typedef struct {char path[40];
char stat[4];
uint64_t filesize;
uint64_t written
} FMupload;
FMupload FMuploads[]={{"","E",0,0},{"","E",0,0},{"","E",0,0},{"","E",0,0},{"","E",0,0}};
const int numFMuploads = sizeof(FMuploads) / sizeof(FMupload);
void setup(){
for(int i=0; i < numFMuploads; i++){
dump(i);
Serial.println("Changing Path");
strcpy(FMuploads[0].path, "/thisfile.txt");
dump(0);
Serial.println("Changing Status");
strcpy(FMuploads[0].stat, "I");
dump(0);
Serial.println("Changing Filesize");
FMuploads[0].filesize = 2048;
dump(0);
Serial.println("Changing Written");
FMuploads[0].written = 1024;
dump(0);
void loop(){
void dump(int i){
Serial.printf("Index: %i Path: %s Status %s Filesize %d Written %d\n", i, FMuploads[i].path, FMuploads[i].stat, FMuploads[i].filesize, FMuploads[i].written);
Produces random output similar to this:
Index: 0 Path: Status E Filesize 0 Written 0
Index: 1 Path: Status E Filesize 1070513980 Written 0
Index: 2 Path: Status E Filesize 1070513980 Written 0
Index: 3 Path: Status E Filesize 1070513980 Written 0
Index: 4 Path: Status E Filesize 1070513980 Written 0
Changing Path
Index: 0 Path: /thisfile.txt Status E Filesize 1070513980 Written 0
Changing Status
Index: 0 Path: /thisfile.txt Status I Filesize 1070516488 Written 0
Changing Filesize
Index: 0 Path: /thisfile.txt Status I Filesize 1070516488 Written 2048
Changing Written
Strange behavior:
Although the array is created with five identical inline objects, the first has the correct filesize of 0 but the others have a big number which is apparently random and changes every time.
After changing the path, the filesize was also changed to a different big number.
After changing the status, the filesize has a different big number in it. The filesize changed when only the status should have.
After changing the filesize, it remains unchanged, but written gets changed instead.
After changing written, no change was made at all.
IDE 1.8.19
ESP32 by Espressif Systems 2.0.14
Can someone please either point out what I am doing wrong or verify that this program simply doesn't work?
Thank you!
