Is TF Mini Plus incompatible with D1 mini (esp8266)?
I need help to get started with TFMini Plus + D1 mini (esp8266). My goal is to perform some kind of "Hello World"-measurement, just to see if I can get things up and running. Nothing complicated at this stage!
Many tutorials out there are referring to the Arduino Uno board, and perhaps I am trying to do something impossible using D1 mini, but this kind of questions are a little too complicated to me to answer right now.
First of all, I found a example repo here: GitHub - TFmini/TFminiPlus-Arduino. In it, there is a picture of an Arduino Uno, but I thought that I could use the code for my D1 mini as well?
This is the code I have used:
#include<SoftwareSerial.h>//header file of software serial port
// SoftwareSerial Serial1(2,3); //I replaced this line with the one down below
SoftwareSerial mySerial(RX,TX); //define software serial port name as mySerial and define pin2 as RX and pin3 as TX
//TFmini Plus related configuration instructions.There are no instructions on display here, you can refer to the TFmini Plus manual to add by yourself. Note: This routine uses serial port to communicate.
char getversion[4]={0x5a,0x04,0x01,0x5f};//Get firmware version
char reset[4]={0x5a,0x04,0x02,0x60};//reset
char enable[5]={0x5a,0x05,0x07,0x00,0x66};//Disable data output
char disable[5]={0x5a,0x05,0x07,0x01,0x67};//Enable data output
char UART[5]={0x5a,0x05,0x0a,0x00,0x69};//Modify communication mode to UART
char I2C[5]={0x5a,0x05,0x0a,0x01,0x6a};//Modify communication mode to I2C
char samplerate_01[6]={0x5a,0x06,0x03,0x01,0x00,0x64};//Set the frame rate  to 1Hz
char samplerate_10[6]={0x5a,0x06,0x03,0x0a,0x00,0x6d};//Set the frame rate  to 10Hz
char samplerate_100[6]={0x5a,0x06,0x03,0x64,0x00,0xc7};//Set the frame rate  to 100Hz
char factoryreset[4]={0x5a,0x04,0x10,0x6e};//Restore factory settings
char save[4]={0x5a,0x04,0x11,0x6f};//save
//The response of TFmini Plus. Note: Output frame rate, output enable switch, return command; Modify communication mode, no response, execute directly
//The response after getting firmware versions
int return_version[7]={0};
//The response after setting samplerate
int return_samplerate[6]={0};
//The response after setting enable switch
int return_switch[5]={0};
//The response after resetting
int return_reset[5]={0};
char reset_success[5]={0x5a,0x05,0x02,0x00,0x60};
char reset_fail[5]={0x5a,0x05,0x02,0x01,0x61};
//The response after restoring factory settings
int return_factoryreset[5]={0};
char factoryreset_success[5]={0x5a,0x05,0x10,0x00,0x6e};
char factoryreset_fail[5]={0x5a,0x05,0x10,0x01,0x6f};
//The response after saving
int return_save[5]={0};
char save_success[5]={0x5a,0x05,0x11,0x00,0x70};
char save_fail[5]={0x5a,0x05,0x11,0x01,0x71};
//prompt information
String info_getversion="get version ok";
String info_reset="reset ok";
String info_enable="enable ok";
String info_disable="get version ok";
String info_UART="UART ok";
String info_I2C="I2C ok";
String info_samplerate_01="samplerate_01 ok";
String info_samplerate_10="samplerate_10 ok";
String info_samplerate_100="samplerate_100 ok";
String info_factoryreset="factoryreset ok";
String info_save="save ok";
//The parameter configuration function, down is the instruction to be written,n1 is the number of downs,buff receives response data,up receives theoretical response data in communication protocols,n2 is the number of buff data,info is the prompt information of corresponding instructions
void configure(char down[],int n1,int buff[],char up[],int n2,String info); //用于比较上行数据是否满足通信协议 1、系统复位2、恢复出厂设置3、保存设置4、波特率5、使能开关
void configure(char down[],int n1,int buff[],int n2,String info);//1、用于不需要比较上行数据的指令 1、获取版本号
void configure(char down[],int n1,String info);//用于UART和I2C的指令
// Define the parameters of receiving LiDAR data
int dist;//actual distance measurements of LiDAR
int strength;//signal strength of LiDAR
int check;//save check value
int uart[9];//save data measured by LiDAR
const int HEADER=0x59;//frame header of data package
int i=0;
//Takes setting the LiDAR samplerate rate at 10Hz as an example, and other settings can be modified accordingly.
  Serial.begin(115200);//set bit rate of serial port connecting Arduino with computer
  mySerial.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
  configure(samplerate_10,6,return_samplerate,samplerate_10,6,info_samplerate_10);
  configure(save,4,return_save,save_success,5,info_save);
// According to the data protocol in TFmini Plus manual, the distance display can be obtained and displayed through serial terminal.
  if (mySerial.available())//check if serial port has data input
	if(mySerial.read()==HEADER)//assess data package frame header 0x59
	  uart[0]=HEADER;
		uart[1]=HEADER;
		for(i=2;i<9;i++)//save data in array
		  uart[i]=mySerial.read();
		check=uart[0]+uart[1]+uart[2]+uart[3]+uart[4]+uart[5]+uart[6]+uart[7];
		if(uart[8]==(check&0xff))//verify the received data as per protocol
		  dist=uart[2]+uart[3]*256;//calculate distance value
		  strength=uart[4]+uart[5]*256;//calculate signal strength value
		  Serial.print("distance=");
		  Serial.print(dist);
		  Serial.print('\t');
		  Serial.print("strength=");
		  Serial.print(strength);
		  Serial.print('\n');
  for(i=0;i<n1;i++)
	 mySerial.write(down[i]);
  bool getdata=false;
  int num=0;
  while(!getdata)
	  if(mySerial.read()==0x5a) //assess communication protocol frame header 0x5a
		buff[0]=0x5a;
		for(i=1;i<n2;i++)
		  buff[i]=mySerial.read();
		for(i=0;i<n2;i++)
		  if(buff[i]==up[i])
			Serial.print(buff[i],HEX);
			Serial.print('\t');
			num++;
		if(num==n2)
		  num=0;
		  Serial.print(info);
		getdata=true;
  getdata=false;
  Serial.print('\n');
  for(i=0;i<n1;i++)
  bool getdata=false;
  while(!getdata)
		if(mySerial.read()==0x5a) //assess communication protoco frame header 0x5a
			buff[0]=0x5a;
			for(i=1;i<n2;i++)
			for(i=0;i<n2;i++)
			   Serial.print('\t');
			Serial.print(info);
			getdata=true;
	  getdata=false;
	  Serial.print('\n');
  for(i=0;i<n1;i++)
  Serial.print(info);
  Serial.print('\n');
[TFminiPlus-Arduino/TFmini_PLUS_Setbaud_EN.ino at master · TFmini/TFminiPlus-Arduino · GitHub]
(in the code above, I have replaced the original line SoftwareSerial Serial1(2,3) with SoftwareSerial mySerial(RX,TX))
I have connected the TF mini plus with my D1 mini like this:
    TF-mini                 D1 mini (esp8266)
    white cable, data in    TX
    green cable, data out   RX
When uploading the sketch (from IDE) to my D1 mini I get this fatal error:
Sketch uses 268500 bytes (25%) of program storage space. Maximum is 1044464 bytes.
    Global variables use 27660 bytes (33%) of dynamic memory, leaving 54260 bytes for local variables. Maximum is 81920 bytes.
    esptool.py v2.8
    Serial port COM8
    Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
      File "C:\Users\XXXX YYYYYY\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in <module>
        esptool.main(cmdline)
      File "C:/Users/XXXX YYYYYY/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
        esp.connect(args.before)
      File "C:/Users/XXXX YYYYYY/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
        raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
    esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
I have tried different pins and configurations but the error remains. Whats the problem here?
Not all of the Arduino ESP code will work with the ESP devices. You have one of several different devices that have the same name, please post a link to it and all of the other hardware pieces. With a little time you will get it working!
