I'm currently working on Self-Balancing Robot. However, my instructor wants me to calculate PID parameters instead of tuning them by hand. If I learn about it correctly, to calculate the PID parameters we need the transfer function. Is there any simple way to calculate it without a transfer function? Or using MPU6050 data to tune it?
If you calculate it, this calculation is called a transfer function.
The MPU data can be used to estimate the tuning parameters. Search for "PID tuning" tutorials to learn how.
Thank you. I mean each design have different transfer function, so how to have transfer function in our design ?
Thank you. Yeah usually people would tuning it by testing many try. However I want to some how calculate it first.
Then you would be calculating the transfer function. Any textbook on process control will explain how.
yeh I had a look through it, I just want find the more simple way to calculate it because this is way too mechanically heavy or having a complicated equation. I guess I'll try to learn it anyway. Thank you for your information.
The control guru website, https://controlguru.com, is what I have used to learn how to measure bump or oscillation responses to then calculate the needed P, I, and/or D parameters. Its recommendations have worked quite well for my robots in the past. The methods discussed on that site don't require Laplace transforms or anything more complicated than high school math.
Thank you. I was afraid of the Laplace transform part.
