The guide is in python though, i need to do it in the arduino IDE. kinda stuck with arduino IDE as the libraries on some portion of my setup is only arduino compatible
Your library examples are in category of UNSUPPORTED in the arduino examples tab.
Will fix in next release of some libraries. As you use mbed_rp2040 core, the slow PWM library to use is MBED_RP2040_Slow_PWM
If the library's examples are not shown or shown as UNSUPPORTED , move down to the INCOMPATIBLE list of examples or open directly from the libraries folder
I am also having a hard time , so the duty cycle parameter what is the value range? 0- 100 because it seem to have a double data type
It's double, so you can use from 0.000-100.000 to have better precision.
