Is the C function kbhit() available for the Arduino
Is there an equivalent of the C function kbhit() for the Arduino?
This function?
This function is not defined as part of the ANSI C/C++ standard. It is generally used by Borland's family of compilers. It returns a non-zero integer if a key is in the keyboard buffer. It will not wait for a key to be pressed.
http://www.cprogramming.com/fod/kbhit.html
No. For one thing, there isn't a keyboard.
I was thinking of using a terminal program like Putty.exe instead of the serial monitor. I would like my program to loop continuously until I hit any key and then exit for example.
In those circumstances, Serial.available() is about the same as kbhit() Serial.available() returns a non-zero integer if a character has been received on the serial port. Putty and the IDE's "Serial Monitor" are equivalent; both would communicate with the arduino via the serial port.
I'll give Serial.available() a try. Thanks
