Is the DHT11 compatible with the OneWire protocol?
Hey, Just wanted to know if I would be able to use this temperature and humidity sensor through the onewire protocol?
anyone knows?
thank you
No, the DHT11 has a different and simpler protocol. I think you can't mix them on the same pin, the DHT11 will probably start responding if something else with OneWire protocol is accessed.
Is the extra pin for the DHT11 a problem ? There are many ways a many trics to reduce the number of used pins.
