Is the interrupt section right?
I am testing the new vision of code with a interrupt function, the line:
 attachInterrupt(1, pressed, FALLING);
and the section:
void pressed() //midle button presed, changing modes
  static unsigned long last_interrupt_time = 0;
  unsigned long interrupt_time = millis();
  // If interrupts come faster than 200ms, assume it's a bounce and ignore
  if (interrupt_time - last_interrupt_time > 220)
    mode++;
    tone(6, 2250, 50);
    if (mode > 5)
      mode = 0;
  last_interrupt_time = interrupt_time;
Neither mentioned the pin3 where the interrupt button attached, but the code works, why? Thanks.
The code:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans18pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <DS3231.h>
// Data wire is plugged into pin 2 on the Arduino
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define XPOS 0
#define YPOS 1
#define DELTAY 2
//clock image
const unsigned char PROGMEM sat1 [] = {
  0x0F, 0x80, 0x01, 0xF0, 0x39, 0xC0, 0x03, 0x9C, 0x61, 0x80, 0x01, 0x86, 0x43, 0x1F, 0xF8, 0xC2,
  0xC6, 0x70, 0x0E, 0x63, 0x8D, 0xC0, 0x03, 0xB1, 0x9B, 0x00, 0x00, 0xD9, 0xF6, 0x01, 0x80, 0x6F,
  0xEC, 0x01, 0x80, 0x37, 0x58, 0x01, 0x80, 0x1A, 0x10, 0x01, 0x80, 0x08, 0x30, 0x01, 0x80, 0x0C,
  0x20, 0x01, 0x80, 0x04, 0x20, 0x01, 0x80, 0x04, 0x20, 0x01, 0x80, 0x04, 0x60, 0x01, 0x80, 0x06,
  0x60, 0x01, 0x80, 0x06, 0x60, 0x7F, 0x80, 0x06, 0x60, 0x00, 0x00, 0x06, 0x60, 0x00, 0x00, 0x06,
  0x20, 0x00, 0x00, 0x04, 0x20, 0x00, 0x00, 0x04, 0x30, 0x00, 0x00, 0x0C, 0x10, 0x00, 0x00, 0x08,
  0x18, 0x00, 0x00, 0x18, 0x08, 0x00, 0x00, 0x10, 0x0C, 0x00, 0x00, 0x30, 0x06, 0x00, 0x00, 0x60,
  0x0F, 0x80, 0x01, 0xF0, 0x18, 0xE0, 0x07, 0x18, 0x30, 0x7C, 0x3E, 0x0C, 0x20, 0x0F, 0xF0, 0x04
//baterry image
const unsigned char PROGMEM baterja [] = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xF0, 0x40, 0x00, 0x00, 0x10, 0x47, 0x3C, 0xE0, 0x18,
  0x47, 0xBD, 0xE0, 0x18, 0x45, 0xA5, 0xA0, 0x1E, 0x45, 0xA5, 0xA0, 0x1A, 0x45, 0xA5, 0xA0, 0x1A,
  0x45, 0xA5, 0xA0, 0x1A, 0x45, 0xA5, 0xA0, 0x1A, 0x45, 0xA5, 0xA0, 0x1E, 0x47, 0xBD, 0xE0, 0x18,
  0x47, 0x3C, 0xE0, 0x18, 0x40, 0x00, 0x00, 0x10, 0x3F, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00,
//continuity test image
const unsigned char PROGMEM continu [] = {
  0x00, 0x1F, 0xF8, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x03, 0xFF, 0xFF, 0xC0, 0x0F, 0xFF, 0xFF, 0xF0,
  0x1F, 0xC0, 0x03, 0xF8, 0x7F, 0x00, 0x00, 0xFE, 0xFC, 0x00, 0x00, 0x3F, 0xF8, 0x07, 0xE0, 0x1F,
  0xF0, 0x3F, 0xFC, 0x0F, 0x00, 0xFF, 0xFF, 0x00, 0x01, 0xFF, 0xFF, 0x80, 0x03, 0xF0, 0x0F, 0xC0,
  0x07, 0xC0, 0x03, 0xE0, 0x03, 0x80, 0x01, 0xC0, 0x01, 0x0F, 0xF0, 0x80, 0x00, 0x1F, 0xF8, 0x00,
  0x00, 0x3F, 0xFC, 0x00, 0x00, 0x3C, 0x3C, 0x00, 0x00, 0x38, 0x1C, 0x00, 0x00, 0x01, 0x80, 0x00,
  0x00, 0x03, 0xC0, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x03, 0xC0, 0x00,
//resistor image
const unsigned char PROGMEM resis [] = {
  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x06, 0x04, 0x00, 0x00, 0x0F, 0x88,
  0x00, 0x00, 0x18, 0xD0, 0x00, 0x00, 0x38, 0x60, 0x00, 0x00, 0x6C, 0x30, 0x00, 0x00, 0xC6, 0x18,
  0x00, 0x00, 0x83, 0x08, 0x00, 0x01, 0x81, 0x8C, 0x00, 0x03, 0x00, 0xCC, 0x00, 0x07, 0x80, 0x78,
  0x00, 0x0C, 0xC0, 0x30, 0x00, 0x18, 0x60, 0x60, 0x00, 0x38, 0x30, 0xC0, 0x00, 0x6C, 0x1B, 0x80,
  0x01, 0xC6, 0x0E, 0x00, 0x03, 0x03, 0x0C, 0x00, 0x07, 0x01, 0x98, 0x00, 0x0D, 0x80, 0xF0, 0x00,
  0x18, 0xC0, 0x60, 0x00, 0x30, 0x60, 0xC0, 0x00, 0x30, 0x31, 0x80, 0x00, 0x10, 0x19, 0x00, 0x00,
  0x18, 0x0F, 0x00, 0x00, 0x0C, 0x06, 0x00, 0x00, 0x06, 0x0C, 0x00, 0x00, 0x0B, 0x18, 0x00, 0x00,
  0x11, 0xF0, 0x00, 0x00, 0x20, 0x60, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00
//diode image
const unsigned char PROGMEM dioda [] = {
  0x00, 0x07, 0xE0, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, 0x3F, 0xFC, 0x00, 0x00, 0x78, 0x1E, 0x00,
  0x00, 0xE0, 0x07, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0xC0, 0x03, 0x00, 0x01, 0xC0, 0x03, 0x80,
  0x01, 0xC0, 0x03, 0x80, 0x01, 0xC0, 0x03, 0x80, 0x01, 0xC0, 0x03, 0x80, 0x01, 0xC0, 0x03, 0x80,
  0x01, 0xC0, 0x03, 0x80, 0x01, 0xC0, 0x03, 0x80, 0x07, 0xFF, 0xFF, 0xE0, 0x07, 0xFF, 0xFF, 0xE0,
  0x07, 0xFF, 0xFF, 0xE0, 0x07, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x1C, 0x38, 0x00, 0x00, 0x1C, 0x38, 0x00, 0x00, 0x1C, 0x38, 0x00, 0x00, 0x1C, 0x38, 0x00,
// logo at starting screen
const unsigned char PROGMEM multilogo [] = {
  0x00, 0x08, 0x61, 0x86, 0x10, 0x00, 0x00, 0x18, 0x61, 0x86, 0x18, 0x00, 0x00, 0x18, 0x61, 0x86,
  0x18, 0x00, 0x00, 0x18, 0x61, 0x86, 0x18, 0x00, 0x00, 0x18, 0x61, 0x86, 0x18, 0x00, 0x00, 0x08,
  0x61, 0x86, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
  0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x00, 0x00,
  0x01, 0x80, 0x79, 0x80, 0x00, 0x00, 0x01, 0x9E, 0xFD, 0x80, 0x00, 0x00, 0x01, 0xBF, 0x01, 0x80,
  0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80,
  0x01, 0x81, 0xFF, 0xFF, 0x81, 0x80, 0xFD, 0x83, 0xFF, 0xFF, 0xC1, 0xBF, 0xFD, 0x83, 0x80, 0x01,
  0xC1, 0xBF, 0x01, 0x83, 0x00, 0x00, 0xC1, 0x80, 0x01, 0x83, 0x00, 0x00, 0xC1, 0x80, 0x01, 0x83,
  0x00, 0x00, 0xC1, 0x80, 0x01, 0x83, 0x00, 0x00, 0xC1, 0x80, 0xFD, 0x83, 0x00, 0x00, 0xC1, 0xBF,
  0xFD, 0x83, 0x00, 0x00, 0xC1, 0xBF, 0x01, 0x83, 0x00, 0x00, 0xC1, 0x80, 0x01, 0x83, 0x00, 0x00,
  0xC1, 0x80, 0x01, 0x83, 0x00, 0x00, 0xC1, 0x80, 0x01, 0x83, 0x00, 0x00, 0xC1, 0x80, 0xFD, 0x83,
  0x80, 0x01, 0xC1, 0xBF, 0xFD, 0x83, 0xFF, 0xFF, 0xC1, 0xBF, 0x01, 0x81, 0xFF, 0xFF, 0x81, 0x80,
  0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x00, 0x00,
  0x01, 0x80, 0xFD, 0x80, 0x00, 0x00, 0x01, 0xBF, 0x79, 0x80, 0x00, 0x00, 0x01, 0x9E, 0x01, 0x80,
  0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x80,
  0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x61, 0x86,
  0x10, 0x00, 0x00, 0x18, 0x61, 0x86, 0x18, 0x00, 0x00, 0x18, 0x61, 0x86, 0x18, 0x00, 0x00, 0x18,
  0x61, 0x86, 0x18, 0x00, 0x00, 0x18, 0x61, 0x86, 0x18, 0x00, 0x00, 0x08, 0x61, 0x86, 0x10, 0x00
DS3231  rtc(SDA, SCL);
Time t;
int pauza = 300; //pause
int raw = 0;
float Vin = 0;
float Vout = 0;
float R1 = 2200;
float R2 = 0;
float vout2 = 0.00;
float vin2 = 0.00;
float res1 = 100000.00; // resistance of R1 (100K)
float res2 = 10000.00; // resistance of R2 (10K)
int val = 0;
float buffer = 0;
void setup()   {
  rtc.begin();
  pinMode(2, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(13, OUTPUT);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x32)
  // init done
  display.clearDisplay();
  display.setFont(&FreeSans9pt7b);
  display.setTextColor(WHITE);
  display.setCursor(0, 32);
  display.print("Multi-");
  display.setCursor(0, 48);
  display.print("druino");
  display.setFont();
  display.setCursor(0, 0);
  display.print("2018");
  display.drawBitmap(64, 8,  multilogo, 48, 48, 1);
  display.display();
  delay(2000);
  display.display();
int mmax = 1; //max
int mmin = 1024; // min
int button = 0;
int mode = 0; //variable for debouncing button
unsigned long numberOfTimes = 0; //number of times
unsigned long sum = 0;
int ave = 0; //average
int pulse = 125; //starting PWM
unsigned long m = 0;
  if (mode == 0)
    if (digitalRead(4) == 0) //analoog read
      delay(100);
      mmin = 1024;
      mmax = 0;
      numberOfTimes = 0;
      sum = 0;
      ave = 0;
    display.setCursor(0, 12);
    display.setTextSize(1);
    display.print("aRead:");
    display.setCursor(95, 0);
    int value = analogRead(A0);
    numberOfTimes = numberOfTimes + 1;
    sum = sum + value;
    ave = sum / numberOfTimes;
    if (value > mmax)
      mmax = value;
    if (value < mmin)
      mmin = value;
    display.setFont();
    int lineW = map(value, 0, 1024, 0, 128); // bottom line lenght
    float voltaza = readVcc();
    display.print(ave);
    display.setCursor(70, 0);
    display.print("AVE:");
    display.setCursor(70, 10);
    display.print("MAX:");
    display.setCursor(70, 20);
    display.print("MIN:");
    display.setCursor(95, 10);
    display.print(mmax);
    display.setCursor(95, 20);
    display.print(mmin);
    display.setFont(&FreeSans18pt7b);
    display.setCursor(0, 62);
    display.print(value);
    display.drawLine(0, 31, lineW, 31, 1);
    display.display();
    if (numberOfTimes > 100000)
    { numberOfTimes = 0;
      sum = 0;
  if (mode == 1)
  { // ohm meter
    display.print("Ohms:");
    display.drawBitmap(96, 0,  resis, 32, 32, 1);
    raw = analogRead(A2);
    Vin = readVcc() / 1000.0;
    buffer = raw * Vin;
    Vout = (buffer) / 1024.0;
    buffer = (Vin / Vout) - 1;
    R2 = R1 * buffer;
    if (R2 < 70000)
      display.print(R2);
    if (R2 > 70000)
      display.print("0");
    display.display();
    delay(pauza);
  if (mode == 2) //dioda drop
    display.drawBitmap(96, 0,  dioda, 32, 32, 1);
    display.print("Voltage");
    display.setCursor(0, 30);
    display.print("Drop:");
    buffer = raw * Vin;
    display.setCursor(0, 63);
    if (Vout == 0)
      display.print("0");
      display.print(Vin - Vout);
    display.display();
  if (mode == 3)
  { //continuiti
    display.drawBitmap(96, -4,  continu, 32, 32, 1);
    display.print("Continuity:");
    buffer = raw * Vin;
    float rez = Vin - Vout;
    if (rez < 1)
      tone(6, 2250);
      display.print("Yes");
      digitalWrite(13, 1);
    if (rez > 1)
      noTone(6);
      digitalWrite(13, 0);
      display.print("No");
    display.display();
  if (mode == 4)
  { //baterry
    display.drawBitmap(96, -8,  baterja, 32, 32, 1);
    display.print("Battery:");
    float volt2 = readVcc() / 1000.0;
    display.print(volt2);
    display.setCursor(69, 62);
    display.print("V");
    display.display();
    delay(pauza);
  if (mode == 5) // pwm generator
    { if (pulse < 255)
        tone(6, 1200, 10);
        pulse = pulse + 5;
    if (digitalRead(2) == 0)
    { if (pulse > 1)
        tone(6, 1400, 10);
        pulse = pulse - 5;
    int lineWidth2 = 0;
    analogWrite(9, pulse);
    display.print("Pulse");
    display.setCursor(0, 28);
    display.print("Width:");
    display.setCursor(0, 60);
    display.print(pulse);
    lineWidth2 = map(pulse, 0, 255, 0, 128);
    display.drawLine(0, 63, lineWidth2, 63, 1);
    display.display();
  /* if(stisnuto==6)
      t=rtc.getTime();
    display.setCursor(0,30);
    display.print(t.hour);
    display.setCursor(40,30);
    display.print(":");
    display.setCursor(50,30);
    display.print(t.min);
    display.setFont(&FreeSans12pt7b);
    display.setCursor(4,62);
    display.print(t.sec);
    display.drawBitmap(96, 0,  sat1, 32, 32, 1);
    display.setCursor(34,62);
    display.print("sec");
    display.display();
    mode++;
    tone(6, 2250, 50);
    if (mode > 5)
      mode = 0;
long readVcc() {
  // Read 1.1V reference against AVcc
  // set the reference to Vcc and the measurement to the internal 1.1V reference
#if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
  ADMUX = _BV(MUX5) | _BV(MUX0);
#elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
  ADMUX = _BV(MUX3) | _BV(MUX2);
#else
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Start conversion
  while (bit_is_set(ADCSRA, ADSC)); // measuring
  uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
  uint8_t high = ADCH; // unlocks both
  long result = (high << 8) | low;
  result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
  return result; // Vcc in millivolts
On a 328, interrupt 1 is associated with pin 3.
You can read about this stuff in the documentation
Thanks.
Do you mean line 328? I did't find that? would you please quote that line?
No, I mean 328, the AVR processor you are most likely using.
(You never actually said which one - I guessed)
wonderful.
Thank you.
Yes, I'll improve my post.
mode should be declared with the 'volatile' keyword and I would recommend changing it to a 'byte'.
If this is a button you really don't need an interrupt. Polling would be sufficient.
Thanks.
Got a new question 'no matching function for call to 'DS3231::DS3231(const uint8_t&, const uint8_t&)'' , I don't know put here OK or should post another one?
Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
multiMultimeter_M:112:21: error: no matching function for call to 'DS3231::DS3231(const uint8_t&, const uint8_t&)'
In file included from E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\Arduino Multimeter and Components Tester\V2\multiMultimeter_M\multiMultimeter_M.ino:16:0:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Arduino-DS3231-master/DS3231.h:89:7: note: candidate: DS3231::DS3231()
 class DS3231
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Arduino-DS3231-master/DS3231.h:89:7: note:   candidate expects 0 arguments, 2 provided
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Arduino-DS3231-master/DS3231.h:89:7: note: candidate: constexpr DS3231::DS3231(const DS3231&)
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Arduino-DS3231-master/DS3231.h:89:7: note:   candidate expects 1 argument, 2 provided
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Arduino-DS3231-master/DS3231.h:89:7: note: candidate: constexpr DS3231::DS3231(DS3231&&)
multiMultimeter_M:113:1: error: 'Time' does not name a type; did you mean 'Wire'?
 Time t;
 Wire
exit status 1
option enabled in File -> Preferences.
Since this thread has been marked solved, it would be best to start a new thread with the code and error description.
There are several different DS3231 libraries with the same name, but they have different syntax. When you start the new thread, please indicate what specific library you are using, and if you didn't write the code, can you find any reference to the specific library used by the author.
Thanks.
I'll pull a new one.
