The library is written for the Arduino and an example sketch is provided.
The code for short messages looks OK.
However, for multi-part messages it looks like the sender can get stuck for 250 milliseconds in a while loop in the ISOTP_WAIT_FIRST_FC state waiting for a handshake response, or a timeout which puts the state back to ISOTP_IDLE, or else encounter an error of some kind.
while(msg->tp_state!=ISOTP_IDLE && msg->tp_state!=ISOTP_ERROR)
On an RTOS you could run this in it's own task so it doesn't block, however on a superloop Arduino I don't see how you would be able to use it in a practical way. Simply reducing the timeout isn't going to work as this will sometimes cause the sending of multi-part message to fail.
If what I'm saying is correct, is there an easy fix?
