Is there a better way to write a sketch.
Hi.
I have done my sketch and it looks messy compared to others I have seen.
What can I do to improve the sketch is my question.
The project description:- Balancing robot controller using a 5D Rocker Joystick Independent Keyboard and a MPU6050. So I use the "Set" and the "Reset" buttons to change between control methods.
The sketch is working. But I am open to a better method of doing that as well.
Sketch below.
The Print to Serial monitor statement's are for debugging only and will be removed before completion of project.
Regards Antony.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
const int up = 6;
const int dwn = 7;
const int let = 8;
const int rht = 9;
const int mid = 10;
const int set = 11;
const int rst = 12;
int buttonState = 0;
int tilt_angle = 15;
int Accelerometer = 0;
byte send_byte;
  while (!mpu.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G))
    Serial.println("Could not find a valid MPU6050 sensor, check wiring!");
  Serial.begin(38400);// 57600
  Serial.print(" Starting up");
  pinMode(up, INPUT_PULLUP);//               on D6
  pinMode(dwn, INPUT_PULLUP);//              on D7
  pinMode(let, INPUT_PULLUP);//              on D8
  pinMode(rht, INPUT_PULLUP);//              on D9
  pinMode(mid, INPUT_PULLUP);//              on 10
  pinMode(set, INPUT_PULLUP);//              on 11
  pinMode(rst, INPUT_PULLUP);//              on 12
  send_byte = B00000000;
  if (Accelerometer == 1) {
    tilt_messure();
  buttonState = digitalRead(let);                         //    white wire to D9
  if (buttonState == LOW) {
    send_byte |= B00000001; Serial.print(" left");        // Left Turn
  buttonState = digitalRead(rht);                        //    yellow wire  to D8
    send_byte |= B00000010; Serial.print(" right");      // Right Turn
  buttonState = digitalRead(dwn);                       //   Blue wire   to  D7
    send_byte |= B00000100; Serial.print(" back");     //   backwards
  buttonState = digitalRead(up);                       //  red wire   to  D6
    send_byte |= B00001000;  Serial.print(" forward"); // forward
  buttonState = digitalRead(set);                      //  yellow wire    to  D11
    Serial.print(" Jumping to Acc");
    Accelerometer = 1;
    tilt_messure();
  /*            Add thease buttons as wanted
    buttonState = digitalRead(mid);                //  green wire   to D10
      send_byte |= B00001000;   // middle button
  Serial.print("          ..     "); Serial.println(send_byte);
  if (send_byte)Serial.print((char)send_byte);
  delay(40);
void tilt_messure() {
  Vector normAccel = mpu.readNormalizeAccel();
  int pitch = -(atan2(normAccel.XAxis, sqrt(normAccel.YAxis * normAccel.YAxis + normAccel.ZAxis * normAccel.ZAxis)) * 180.0) / M_PI;
  int roll = (atan2(normAccel.YAxis, normAccel.ZAxis) * 180.0) / M_PI;
  // Serial.print(" Pitch = ");
  // Serial.print(pitch);
  //  Serial.print(" Roll = ");
  //Serial.print(roll);
  if (pitch <= -tilt_angle) {
    Serial.print(" left");// Left Turn
  if (pitch >= tilt_angle) {
  if (roll <= -tilt_angle) {
  if (roll >= tilt_angle) {
  Serial.print(send_byte);
  delay(10);
  buttonState = digitalRead(rst);                  // Green wire   to  D12
    Accelerometer = 0;
To start;
const int up = 6;
const int dwn = 7;
const int let = 8;
const int rht = 9;
const int mid = 10;
const int set = 11;
const int rst = 12;
Make.
const int upPin = 6;
const int dwnPin = 7;
const int letPin = 8;
const int rhtPin = 9;
const int midPin = 10;
const int setPin = 11;
const int rstPin = 12;
Have you pressed CTRL-T in the IDE to Auto Format your code?
Tom... :slight_smile:
Or even better
const byte upPin = 6;
const byte dwnPin = 7;
const byte letPin = 8;
const byte rhtPin = 9;
const byte midPin = 10;
const byte setPin = 11;
const byte rstPin = 12;
Thanks for the reply's.
Yes I can see that it is better to label things that is more meaning full. :slight_smile: :slight_smile: Changes Made. Will do this in the future.
UKHeliBob:
Or even better
Yes I did some research into this byte v int
:- Better practice and it saves on memory. Also changes made..
Thanks for your input:)
Regards Antony.
AntonyG:
consider (avoid redundant code)
#if 0   // my hardware
enum { MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G };
struct  Vector {
    int     XAxis;
    int     YAxis;
    int     ZAxis;
struct MPU6050 {
    bool begin (int a, int b) { return true; };
    Vector readNormalizeAccel (void) { return {}; };
const byte up  = A1;
const byte dwn = 3;
const byte let = A2;
const byte rht = 4;
const byte mid = 5;
const byte set = A3;
const byte rst = 6;
#else
#include <Wire.h>
const byte up = 6;
const byte dwn = 7;
const byte let = 8;
const byte rht = 9;
const byte mid = 10;
const byte set = 11;
const byte rst = 12;
#endif
MPU6050 mpu;
byte pins [] = { up, dwn, let, rht, mid, set, rst };
struct Cmd_s {
    byte    pin;
    byte    val;
    byte    acc;
    const char *str;
    byte    state;
Cmd_s cmds [] = {
    {  up,   B00001000, 0, " forward" },
    {  dwn,  B00000100, 0, " back" },
    {  let,  B00000001, 0, " left" },
    {  rht,  B00000010, 0, " right" },
    {  mid,  0,         0, " mid" },        // placeholder
    {  set,  0,         1, "" },
    {  rst,  0,         0, "" },            // unused
#define N_CMDS  (sizeof(cmds)/sizeof(Cmd_s))
byte  send_byte;
const char *cmdStr;
char s [80];
    Serial.println (" Starting up");
    for (unsigned n = 0; n < sizeof(pins); n++)
        pinMode (pins [n], INPUT_PULLUP);
        tilt_messure();
    Cmd_s  *p = cmds;
    for (unsigned n = 0; n < N_CMDS; n++, p++)  {
        buttonState = digitalRead (cmds [n].pin);
        if (p->state != buttonState)  {
            p->state = buttonState;
            delay(10);                  // debounce
            if (HIGH == p->state)
                continue;
            if (p->val)  {
                send_byte = p->val;
                cmdStr    = p->str;
            else if (p->acc)
                Accelerometer = ! Accelerometer;
    if (send_byte)  {
        sprintf (s, "   0x%02x  %s", send_byte, cmdStr);
        Serial.println (s);
    delay(40);
void
tilt_messure()
    if (0)  {
        sprintf (s, "  pitch %4d, roll %4d", pitch, roll);
        Serial.println (s);
        cmdStr = " left";
    else if (pitch >= tilt_angle) {
        cmdStr = " right";
    else if (roll <= -tilt_angle) {
        cmdStr = " back";
    else if (roll >= tilt_angle) {
        cmdStr = " forward";
        Serial.println ("tile_measure:");
    // values get printed in loop()
gcjr:
struct  Vector {
   int     XAxis;
   int     YAxis;
   int     ZAxis;
struct MPU6050 {
const byte up  = A1;
const byte dwn = 3;
const byte rht = 4;
const byte mid = 5;
const byte rst = 6;
#else
#include <Wire.h>
const byte up = 6;
const byte dwn = 7;
const byte let = 8;
const byte rht = 9;
#endif
MPU6050 mpu;
struct Cmd_s {
   byte    pin;
   byte    val;
   byte    acc;
   const char *str;
   byte    state;
Cmd_s cmds [] = {
{  set,  0,         1, "" },
byte  send_byte;
const char *cmdStr;
char s [80];
       tilt_messure();
Cmd_s  *p = cmds;
               continue;
if (p->val)  {
               send_byte = p->val;
               cmdStr    = p->str;
           else if (p->acc)
if (send_byte)  {
       Serial.println (s);
delay(40);
void
tilt_messure()
   if (0)  {
       Serial.println (s);
       cmdStr = " left";
       cmdStr = " right";
       cmdStr = " back";
You may have changed the logic from that in the OP because pitch and roll do not appear to be directly coupled there allowing, in a single iteration, say : Left Turn, Backwards. Your if / then / else if / else precludes this.
6v6gt:
there are a lot of issues. but consider that send_byte is only sent once, so last set is the value sent.
Warning: You have a Serial.println() in setup() before the Serial.begin().
You have Pitch (nose up, nose down) associated with left/right and Roll (tilt left, tilt right) associated with forward/backward. This will be confusing to anyone who knows what the words mean. I think your accelerometer is in sideways.
Hi.
Gcjr .. That is a lot of strange code to me. I will study and play with it.
The only issue would be that in the button input stage it does not keep repeating the send.
I have to keep pressing the button to achieve this.
Its way interesting to compare the code.. Will play with it for a while. Thanks.
6v6gt..
At this point in time I have no idea on what to look for..
gcjr..
Thanks . Yes I spotted that after I loaded the code onto the forum.
That I found because it did not print the Start up message.
Thanks for all the reply's.. Its given me something to do.
Regards Antony.
Things I would consider changing:
  1. Definitions for your pins are variables which are only ever referred to in setup(). I'd personally make them preprocessor macros (e.g. #define UP_PIN 6). I think this probably saves some RAM, but from the perspective of a reader of the sketch helps them understand that these are not variables and hence there's no need to check for when/where they are written to.
  2. Make send_byte local to loop(). It gets reset every time around loop(), so there's no intrinsic value to it having a global scope. I appreciate that tilt_measure() accesses the variable, but this could be resolved by having tilt_measure() return a value, or passing a pointer to send_byte to tilt_measure(). By making send_byte local to loop() it's easier to review how and where the variable is used.
  3. Look into debouncing the various buttons, e.g. https://www.arduino.cc/en/pmwiki.php?n=Tutorial/Debounce
  4. Separate concerns. tilt_measure() currently reads the accelerometer, does some serial logging, modifies send_byte, delays a bit, and reads the rst pin. In other words, it does a lot more than its name suggests. Personally I would try to implement tilt_measure() such that it just reads the accelerometer sensor data and performs the maths to resolve pitch and roll values (I would pass these results out from the function). By doing so, the sketch is easier to follow since tilt_measure() is just doing what it says on the tin, and the reader doesn't need to worry about all the "other" things the function does.
  5. loop()'s handling of the Accelerometer variable looks a bit odd to me. If Accelerometer is 1, then tilt_measure() is called. However, the code then goes on to read the states of the direction buttons. My reading of your description is that the control mechanism should be either accelerometer or buttons, but not both at the same time.
Btw -- I have mentioned "the reader" a couple of times. Sometimes that reader is someone else. More often that reader is yourself six months down the line when you can't remember how the code was supposed to work in the first place :slight_smile:
buttonState seems redundant. Consider:
  // vs.
  if (digitalRead(let) == LOW) {                         //    white wire to D9
YMMV
Hi.
tomparkin..and gcjr..
Thank you for your input.
I have made thebyte send_byte = 0; a local.
Sooo much to learn.
Thanks Again.
Antony.
