Is there a driver for a 6 digit TM1637 display?
I have bought a 6 digit display (normally they have at most 4 digits).
I wonder if there is a library which can handle 6 digits (without doing hacks)?
Here is the link: https://www.aliexpress.com/item/32797225659.html
Most TM1637 libraries seem to assume a 4-digit display and use the unused two digits to light a colon or similar.
The arduino-tm1637/SevenSegmentTM1637.h at master · bremme/arduino-tm1637 · GitHub file has
  // SevenSegmentTM1637 low level methods (use when you know what you're doing)
  /* Prints raw (encoded) bytes to the display
  *         A
  *       ___
  *  * F |   | B
  * X     -G-
  *  * E |   | C
  *       ___
  *        D
  * Bit:      76543210
  * Segment:  XGFEDCBA
  * For example to print an H, you would set bits BCEFG, this gives B01110110 in binary or 118 in decimal or 0x76 in HEX.
  * Bit 7 (X) only applies to the second digit and sets the colon
  /* Print raw (binary encodes) bytes to the display
  @param [in] rawBytes      Array of raw bytes
  @param [in] length        optional: length to print to display
  @param [in] position      optional: Start position
  void    printRaw(const uint8_t* rawBytes, size_t length = 4, uint8_t position = 0);
  @param [in] rawByte       Raw byte
  void    printRaw(uint8_t rawByte, uint8_t position);
  /* Write command to IC TM1637
  @param [in] cmd         command to send
  @return acknowledged?   command was (successful) acknowledged
So it is up to you to write regular 7-segment values to digits 5, 6.
The TM1638 is intended for 8 digit + two colons
The TM1637 is intended for 6 digit. (or 4-digit + two colons)
David.
