Hello all
I have posted related topics in the past but for anyone who wants to know I am coding a game controller using an Arduino Leonardo. It works pretty well. I have 4 buttons and a joystick. What I do is I have the buttons and joysticks coded to Keyboard.write a specific key such as w, a, s, d.
My problem is that for my joystick, instead of having a button to hold down a key, it just presses the key over and over again. For example, when I hold left on the joystick, it presses the same key over and over again instead of holding it down. This is a problem because my characters in game go at half the speed as they always move a little and then stop over and over again.
I guess what my question is, is that is there a command like Keyboard.write that holds down the key instead of pressing it once?
Thanks in advance
You need to detect when the joystick becomes pushed in a direction rather than when it is in a direction. Look at the StateChangeDetction example in the IDE
Thank you, this is good progress.
However, I am unsure what StateChangeDetection is and how I use it. It this a command I can use? If so, how does it work and how do I use it?
Squidnugget65:
It's in the example sketch tab in the IDE File menu.
read the joystick input as the current direction
if the current direction is not equal to the previous direction then the joystick has moved
if the joystick is now left
do whatever you need when the joystick is left
end if
save the current direction as the previous direction ready to test again next time
end if
UKHeliBob:
end if
end if
Ok awesome, thanks for the help.
