How can I check if sound of frequency 3600Hz is being played, using the ky-038 sound sensor?
I've been looking at different forums and libraries but couldn't find anything...
The very first thing Google found was this sentence:
"This sensor emits a signal if the microphone of the sensor detects a noise. The sensitivity of the sensor can be adjusted by means of a controller.".
Obviously the device does not and cannot measure anything except the LOUDNESS of a sound.
Sorry. Need something else for a sensor,and then some way to separate one sound from all the others being heard by the sensor.
Hi @world_tan
FYI
Convert the analog signal of the sensor with an ADC to numerical values, then apply a FFT function to a number of samples. This is the approved way for any frequency analysis, since many decades.
FFT stands for Fast Fourier Transform. There is a library arduinoFFT, but I have no idea if it powerful enough to do what you want. Audio frequency analysis is not too demanding, so it should be feasible with a somewhat faster CPU.
You are in for a lot of fun. Signals analysis is very interesting, and you can use a good library without getting too deeply involved in the maths behind FFT.
Cheers,
Ekki
Yep, should do OK:
ArduinoFFT - Open Music Labs Wiki
I have used the lib years back as a VU'ish spectrum meter.
This may be preferred over FFT for monotone
Goertzel Algorithm - Arduino Project Hub
But, one could throw h/w pre-processing ahead of the Arduino
Autocorrelation is very simple, and for audio tones outperforms the FFT analysis.
