I am thinking a on-site arduino and temp sensor and connect to ethernet since I can have a cable from my hub to the place.
Thanks
Thanks
You could use labview or profilab expert to import data;process and store them in excel format for instance. Then process them further in excel if needed.
Thanks, software side doesn't bother me much. I just need more info on the hardware side.
Do I just need a Arduino mother border, a ethernet shield and a DHT11? do I need do some wielding? or just wire connects?
And I heard DHT11 is not stable for temperature connection, any idea in that?
i like to use a LM35 solderd to an ATtiny13, which talks via a single cable...
the LM35 needs an analog pin and is quite accurate...
that should work with an arduino and UART/Ethernet, too...
ATtiny13 is cheap, it is good if it works, could you give me more info about LM35+ATtiny13 and talks to PC?
Thanks
Also, what about LHT11 compare to LM35, I would rather do less soldering, if LHT 11 is not accurate enough, will LM35 be?
wyx2000:
You haven't stated what level of accuracy (or more likely precision) that you require, but you can find those specs if you do a little googling. Also, if the sensor (just one sensor?) will not be within a few feet of the Arduino please state so.
The sensor will be with Arduino, and thinking connect Arduino to main PC by ethernet. The idea is I can have a Arduino on-site to monitor everything and feed back to main server by wire.
do u mean this:
http://www.micropik.com/PDF/dht11.pdf ?
u need to measure humidity, 2?
this one is more accurate (regarding temperature), but unable to measure humidity:
RIDDICK:
do u mean this:
http://www.micropik.com/PDF/dht11.pdf ?u need to measure humidity, 2?
http://www.ti.com/lit/ds/symlink/lm35.pdf
Right, I know there are DHT11 and LM35, and kind know LM35 is more accurate, but as I asked above, they are not same, DHT11 is a board, while LM35 is just a part, not sure what are the right words for them, I mean it seems LM35 is very basic and need more welding work, not something just plug or wired like DHT11.
u can plug the LM35 into the arduino sockets, too...
without any soldering...
just wrap a wire tightly around its legs and then secure it with duct tape...
the DHT would need some wires, 2...
RIDDICK:
just wrap a wire tightly around its legs and then secure it with duct tape...the DHT would need some wires, 2...
Thanks, that is what I want to know.
MacGyver rulz... 8)
DHT is not really "a board", but doesn't "need wires" either. It's probably best described as a thru-hole component
So you can either plug it in Arduino pins or in a remote PCB or solder wires on its pins.
The DHT22 (4-5USD in China) has a better (0.1 degree) resolution. But more important, it has a digital interface, hence is not sensible to analog noise on a wire ! Also sold as PCB modules with pull up and decoupling cap for a few bucks more.
