Is there a problem or something
#include <DHT.h>
#define Type DHT11
int sensePin=8;
DHT HT (sensePin,Type);
float humidity;
float tempC;
float tempF;
int setTime=500;
int ButtC=9;
int ButtF=10;
int ButtL=11;
int LightVal;
int LightP=A0;
  HT.begin();
  delay(setTime);
  pinMode(LightP,INPUT);
  humidity=HT.readHumidity();
  tempC=HT.readTemperature();
  tempF=HT.readTemperature(true);
  LightVal=analogRead(LightP);
  if (ButtC==HIGH) {
    Serial.print("C");
    Serial.println(tempC);
  if (ButtF==HIGH) {
    Serial.print("F");
    Serial.println(tempF);
  if (ButtL==HIGH) {
    Serial.print("Light= ");
    Serial.println(LightVal);
Because it keeps saying it's wrong.
Here is my format:
if (ButtC==HIGH)
ButtC is 9 so how can in be HIGH
Did you want:
if (digitalRead(ButtC)==HIGH)
There are others too . . .
Your switches are wired wrong.
Use the below format:
if(digitalRead(ButtF) == HIGH)
Thanks for the information given, I'm a beginner so I don't actually understand the stuff.
It says some strange things over here.
Code:
#include <DHT.h>
#define Type DHT11
int sensePin=8;
float humidity;
float tempC;
float tempF;
int setTime=500;
int ButtC=9;
int ButtF=10;
int ButtL=11;
int LightVal;
int LightP=A0;
  HT.begin();
  delay(setTime);
  pinMode(ButtC,INPUT_PULLUP);
  pinMode(ButtF,INPUT_PULLUP);
  if (digitalRead(ButtC)==HIGH) {
    Serial.print("C");
  if (digitalRead(ButtF)==HIGH) {
    Serial.print("F");
  if (digtalRead(ButtL==HIGH)) {
This is my format:
Why are you opening up a new thread ?
What ?
Because it still doesn't work. :person_tipping_hand: :person_tipping_hand: :roll_eyes:
You should then carry on with the thread rather than opening up a new one.
What seems to be the problem now ?
Do you have a DH11, 21 or 22 ?
If you are looking for a switch push/close, change to:
if (digitalRead(ButtC)==LOW)
I have merged your cross-posts @albert_wu1234.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I'm using a DHT11
Spelling and syntax:
if (digitalRead(ButtL)==HIGH) {
#include <DHT.h>
#define Type DHT22
const byte LightP      = A0;
const byte sensePin    = 8;
const byte ButtC       = 9;
const byte ButtF       = 10;
const byte ButtL       = 11;
int setTime            = 500;
int LightVal;
float humidity;
float tempC;
float tempF;
DHT HT (sensePin, Type);
  HT.begin();
  delay(setTime);
  pinMode(ButtC, INPUT_PULLUP);
  pinMode(ButtF, INPUT_PULLUP);
  pinMode(ButtL, INPUT_PULLUP);
} //END of   setup()
  humidity = HT.readHumidity();
  tempC = HT.readTemperature();
  tempF = HT.readTemperature(true);
  LightVal = analogRead(LightP);
  if (digitalRead(ButtC) == LOW)
    Serial.print("C ");
  if (digitalRead(ButtF) == LOW)
    Serial.print("F ");
  if (digitalRead(ButtL) == LOW)
    Serial.print("Light = ");
} //END of   loop()
There's nothing wrong with the syntax (the compiler would've bitched if there were), it's just that the semantics are wrong. :sunglasses:
