Is there a shield for Orient Display AFY480272B0-4.3N12NTM-C?
I've looked, but been unable to locate, an Arduino shield for Orient Display 4.3 (AFY480272B0-4.3N12NTM-C). I'm new to Arduino and have one of these displays I'd like to incorporate in one of my first uses.
Thank you in advance!
Welcome.
It generally helps others to help you if you post a link to the item you are having trouble with. A link to a datasheet, for example, will help those trying to help you.
The LCD shields I've seen generally come as a complete item of the shield and the LCD.
I'm not aware of a shield that you can plug your own LCD into. It's possible that there too many variations on the pinouts of the LCD "ribbon" cable amongst the hundreds of LCDs out there to make such a shield feasible. But then again, I may be wrong here as I've had to do what you are trying to do.
Thank you. Being a noob with Arduino, I wasn't sure, but be thought I'd posted enough info about the TFT screen in question. More to learn! Thanks again for the response
