is there a way to disable one of the digital ports
i whant to run 6 LED’s on three outputs but then i have to disable one of the pins.
here is my code
int led1 = 13;
int led2 = 12;
int led3 = 10;
void setup(){
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
void loop(){
  digitalWrite(led1,HIGH);
  digitalWrite(led2,LOW);
  digitalWrite(led3,LOW);
  digitalWrite(led1,LOW);
  digitalWrite(led3,HIGH);
  digitalWrite(led2,HIGH);
Could you state that as a question, please?
-br
billroy:
-br
i want to disable one of my digital outputs
  digitalWrite(led2,LOW); //disable this in stead of having it low
"How do I disable an output?"
Set its pinMode to INPUT.
-br
This thread intrigues me... why do you need to disable the pin?
What are you expecting to happen when you disable the pin/port?
Maybe have a look at charlie-plexing - http://www.instructables.com/id/CharliePlexed-LED-string-for-the-Arduino/ -
ingar195: i whant to run 6 LED's on three outputs but then i have to disable one of the pins.
Are you doing Charlieplexing Try this Library http://playground.arduino.cc/code/charlieplex
