Is there a way to measure the torque of a Stepper motor
Hi All -
Wondering if there is a way to measure the torque of a Stepper motor, I'm working on a application, where it is critical to measure the torque and control the end product output based on the torque.
Any insights into this will be highly appreciated.
Thanks in advance
Best
First is to have a program that can step the motor. Do you have such a program?
Paul
rockwellramesha:
I infer from that that your purpose for measuring the torque is so that you can control the torque. It is not practical to control the torque of a stepper motor while it is operating. The torque is determined by the limiting current permitted by the stepper motor driver and I am not aware of any driver that allows that to be controlled by an Arduino. It is usually set manually with a potentiometer or DIP switches.
The better stepper motor manufacturers publish graphs that show the torque at different speeds and currents.
And, even if you could reduce the torque the effect would be to cause the motor to miss steps which would completely nullify the value of a stepper motor.
If you have an application where torque-control is important then a regular DC motor will almost certainly be more suitable.
...R
Thanks Robin2
rockwellramesha:
Hi All -
Thanks in advance
Best
Which torque? dynamic torque? holding torque?
Perhaps you mean measure the load torque at a particular moment? That requires a torquemeter on
a rotating shaft, not easy.
You can't measure torque electrically with a stepper. A DC motor is much more amenable to this.
Dynamic torque
Google for "motor torque sensor" and look at the images. There are many, many sensors you can use.
Paul
