This is a door lock system that turns on a magnetic strike if an SMS or a signal from a bluetooth device is received. It also has an image capturing feature via adafruit motion camera.
Everything works fine, except that when an image is being written in the SD card, serial communications are "paused" until data transfer is done. While the transfer is in process, it does not read any signal or message from SMS and bluetooth, when transfer is finished, it is the time when the board will read any sent data from the SMS and bluetooth. Is there a way that we can still read data from the bluetooth and sms even if the data transfer is in progress, like an interrupt of sort? thanks in advance for the response.
Here is the code(sorry if it's constructed poorly):
//SIM900D library
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
//SD Card Library
#include <SD.h>
#define chipSelect 53
//Camera library
#include <Adafruit_VC0706.h>
Adafruit_VC0706 cam = Adafruit_VC0706(&Serial1);
// PIR Variables
int pirPin = A0; // Sensor input
int sensorValue = 0;
int buzzer;
// SMS Variables
int numdata;
boolean initialized = false; //Initialize loop.
char smsbuffer[160];
char n[20];
char StrikeKey[100] = "UNLOCK"; // Message to Unlock strike.
int StrikePin = 13; //Strike Pin.
char AdminNumber[20];
char AdminNumber1[20];
// Variables to be read by serial terminal (SMS)
char sms_position;
char phone_number[20];
char sms_text[100];
int i;
// SMS Trigger Variables
boolean motionSensed = false;
//Camera
#if !defined(SOFTWARE_SPI)
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
if(chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega
#else
if(chipSelect != 10) pinMode(10, OUTPUT); // SS on Uno, etc.
#endif
#endif
Serial.println("VC0706 Camera test");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
// Try to locate the camera
if (cam.begin()) {
Serial.println("Camera Found:");
Serial.println("No camera found?");
return;
// Print out the camera version information (optional)
char *reply = cam.getVersion();
if (reply == 0) {
Serial.print("Failed to get version");
Serial.println("-----------------");
Serial.print(reply);
// Set the picture size - you can choose one of 640x480, 320x240 or 160x120
// Remember that bigger pictures take longer to transmit!
//cam.setImageSize(VC0706_640x480); // biggest
cam.setImageSize(VC0706_320x240); // medium
//cam.setImageSize(VC0706_160x120); // small
// You can read the size back from the camera (optional, but maybe useful?)
uint8_t imgsize = cam.getImageSize();
Serial.print("Image size: ");
if (imgsize == VC0706_640x480) Serial.println("640x480");
if (imgsize == VC0706_320x240) Serial.println("320x240");
if (imgsize == VC0706_160x120) Serial.println("160x120");
// Motion detection system can alert you when the camera 'sees' motion!
cam.setMotionDetect(true); // turn it on
//cam.setMotionDetect(false); // turn it off (default)
// You can also verify whether motion detection is active!
Serial.print("Motion detection is ");
if (cam.getMotionDetect())
Serial.println("ON");
Serial.println("OFF");
if (!SD.begin())
Serial.println("initialization failed!");
Serial.println("initialization done.");
File Number1 = SD.open("Admin.txt");
if (Number1) {
// read from the file until there's nothing else in it:
while (Number1.available()) {
AdminNumber[20] = Serial.write(Number1.read());
File Number2 = SD.open("Admin.txt");
if (Number2) {
while (Number2.available()) {
AdminNumber1[20] = Serial.write(Number2.read());
Serial.println("error opening test.txt");
//Camera Setup
// Pin Mode
pinMode(pirPin, INPUT);
pinMode(StrikePin, OUTPUT);
// Pin Initial State
digitalWrite(StrikePin, LOW);
//Blueooth Baud Rate
Serial2.begin(9600);
// GSM Baud Rate
// Loop Void Functions
MotionDetectCamera();
/*if (digitalRead(4) == HIGH)
initialized = true;
gsm.begin(9600);*/
if (initialized == true)
sensor();
strikeSMS();
void serialEvent2()
byte BluetoothVal = Serial2.read();
Serial2.read();
if (BluetoothVal == 5)
digitalWrite(StrikePin,HIGH);
Serial.print("OPEN");
delay(10000);
digitalWrite(StrikePin,LOW);
void sensor()
// Read sensor value, if value > 0, motion = true
sensorValue = analogRead(pirPin);
if (analogRead(sensorValue) > 0)
motionSensed = true;
Serial.println(motionSensed);
void strikeSMS()
sms_position=sms.IsSMSPresent(SMS_UNREAD);
if (sms_position)
// Print Variables.
Serial.print("SMS postion:");
Serial.println(sms_position,DEC);
sms.GetSMS(sms_position, phone_number, sms_text, 100);
Serial.println(phone_number);
Serial.println(sms_text);
// Read last message, then Turn on Strike
if ((strstr(sms_text, StrikeKey)) && ((strstr(phone_number, AdminNumber)) || (strstr(phone_number, AdminNumber1))))
delay(5000); // Turn off after 5 Seconds
sms.DeleteSMS((int)sms_position); // Delete message to free space.
Serial.println("Message Deleted.");
else if ((strstr(sms_text, !StrikeKey)) || ((strstr(phone_number, !AdminNumber)) || (strstr(phone_number, !AdminNumber))))
sms.SendSMS(phone_number, "Invalid Key!");
void SMSnotification()
// If PIR sensed Motion...
if (motionSensed == true)
if (sms.SendSMS(AdminNumber, "Someone entered the hall. Possible infiltrator may be inside."))
Serial.println("\nSMS sent OK.");
Serial.println("\nError sending SMS.");
void MotionDetectCamera(){
if (cam.motionDetected()) {
Serial.println("Motion!");
if (! cam.takePicture())
Serial.println("Failed to snap!");
Serial.println("Picture taken!");
char filename[13];
strcpy(filename, "IMAGE00.JPG");
for (int i = 0; i < 100; i++) {
filename[5] = '0' + i/10;
filename[6] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
File imgFile = SD.open(filename, FILE_WRITE);
uint16_t jpglen = cam.frameLength();
Serial.print(jpglen, DEC);
Serial.println(" byte image");
Serial.print("Writing image to "); Serial.print(filename);
while (jpglen > 0) {
// read 32 bytes at a time;
uint8_t *buffer;
uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
buffer = cam.readPicture(bytesToRead);
imgFile.write(buffer, bytesToRead);
//Serial.print("Read "); Serial.print(bytesToRead, DEC); Serial.println(" bytes");
jpglen -= bytesToRead;
imgFile.close();
Serial.println("...Done!");
cam.resumeVideo();
