Is there any arduino board that i can connect to my pc using my phones charging cable?
hello . im a begginer and i want to buy a type of arduino that i can connect it to my laptop using my phone chargers cable? i really need that kind of arduino because i dont wanna waste my money on buying a weird looking fat cable just to use arduino
We don't know what your phone charger cable looks like
Hi
My crystal ball is not entering the WEB and I had it fixed, but if you tell me about your phone cable, maybe we can help.
RV mineirin
ill give you the image jut wait
shopping
usb cable type a/b standard usb 2.0 cable
A standard USB cable has data wires in it as well as power wires whereas a charger cable may not. Can you use the cable to copy data from the 'phone to the PC ?
yes i can
i wanted the type of arduino board that i can use usb cable type a/b standard usb 2.0 cable on it not if i can transfer data or not
Then you can use it with an Arduino as long as the Arduino has the correct USB connector or can be used with an adapter.
So, what type of USB connector does your cable have on the 'phone end ? Is it a micro USB connector ?
its micro usb . also i have to say that i dont want to use my phone to write code(or thats imposible) i want to use my laptop
I understand what you want to do but frankly I don't understand what you are worried about. Why not buy an Arduino and a suitable USB cable to connect it to your PC. The cables are as cheap as chips and it is an unusual household that does not already have several of them of different types
how much does the cable for arduino uno costs?
You just need a standard USB cable with the correct USB connector
For instance, an Arduino Nano uses a mini USB connector like this 1PCS Black 5 Pin Mini USB Charger Cable Cord for MP3 MP4 PMP Media Player 80cm | eBay
1 dollar? that would be half of my pocket money
Are there no spare USB leads in your household ?
nope
i will have to go in mins
Ok, so let's assume that you must use the USB cable that you usually use to charge your 'phone and to transfer data from it. That means you need an Arduino with a micro USB connector such as the Nano Every Arduino Nano Every — Arduino Official Store
But if you can't afford 99c for a cable then you will not be able to afford any Arduino board
ok . thanks for your help . bye
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to [url=https://forum.arduino.cc/index.php?topic=710766.0]Learn How To Use The Forum[/url].
Other general help and troubleshooting advice can be found here.
