Is there any difference between antennas ?
Hello is there any difference between this Quad-band Cellular Duck Antenna SMA - CEL-00675 - SparkFun Electronics and a standard wifi router antenna ? I want to connect my antenna to GSM/GPRS Module - SM5100B - CEL-09533 - SparkFun Electronics and want to know if its compartible or i will need to buy a new one...
The female to male connector is not what considers me...
invader7:
Well that appears to be a multi-band antenna covering several different RF frequency bands. Is a 'standard wifi router antenna' usually a mulitband or just covering the standard wifi band. I would think the latter.
Lefty
I've not done GSM, but it apparently works on the 900 and 1800 Mhz bands. However, wifi operates
on the 2.4 Ghz band, so a wifi antenna would probably not be appropriate. Mistuned.
thanks !
