Is there any thing can i used to detect an bacteria or viruses for iot project?
Hello everyone, I have an project on internet of things
First off all plase pardon me for my english!
I want to make a device that can detect a viruses or bacteria, then can automatically controlled over internet. The Idea is That The device should be placed on the river nowhere in my country, then it should upload the data about the condition of the water in that river..
Is there any Sensor maybe can i use? or i need to make it ?
Thanks for your time
Bacteria and viruses are essentially everywhere, so any sensor that works would always detect them.
The only exceptions would be extremely carefully sterilized environments, or fires, ovens, molten metals etc. where temperatures exceed about 150C.
Making such a detector is not an Arduino project.
I think that the Star Trek TV and movie series led to the idea that there is a sensor for everything.
"No life forms on that planet, Captain!"
Bacteria fluoresce when you shine UV light on them. A probe that includes a light source, and a detector at a 90 degree angle will detect that fluorescence. You will need to calibrate the sensor, and it won't detect viruses.
Delta_G:
Only a subset. Definitely not all of them.
True, however polluted water is populated by fluorescing bacteria. They make fiber optic probes to test water for bacteria content that way. Here's an article.
Delta_G:
The only true test is to either grow them out or do PCR.
"True test" - dna, of course. But I don't think that's what the OP was looking for. They stated "I want to make a device that can detect a viruses or bacteria". I believe the fluorescence detector (with enzymatic preparation) does exactly that.
I don't know of a way to detect viruses, but my student, Mo Elzein, got his degree by developing this e.coli sensor. I don't claim expertise, but I did work with him to support his research. It's since been commercialized, and is currently being used to monitor waster sources. I'm convinced it works.
Here's another article based on Mo's dissertation.
I know how it works, and this is indeed several steps from my initial statement that "bacteria fluoresce". You are likely right that there will never be an instant bacteria identifier. But I think the OP just wants to know if there is poop in the water.
Indeed taking a long road to a dead end sucks. Perhaps a thing that tells folks if their water is potable would be a hit though. You know, iot...
Boil water for 30 minutes to inactivate all organisms, including bacteria and viruses. The water still might not be potable.
Sample into a microscope cell, robotic microscope using CV methods assays the types of cells. Doesn't work
for viruses though, probably hopeless at low concentrations without some sort of microfluidic filtering
system to preprocess significant volumes.
I think the consensus is there is no cheap way to do anything like a good job. Pay people to take
samples regularly and post them to a lab.
If you want to measure how hazy the water is, that's another matter!
Grab an Arduino jar and weigh it empty. Then fill the Arduino jar up with the river water and weigh it again. After that use the Arduino water heater to evaporate all of the water. Using your Arduino scale measure the weight without water. There should be a delta weight. The new weight is how much not water is in the jar. Next using the Arduino furnace raise the temp to burn off non plant organics. Weight it again. That's how much bacteria was in the jar. To finish though you have to once again use your Arduino kiln to melt all of it and measure the gas chromographies flying out with your Arduinichrome. What's left is Corona.
Gravimeter much?
I ran a harmonised water quality lab on behalf of the EU.
"Water condition" covers chemical, physical and micro-organisms. The number of tests to get a reasonably good picture ran into hundreds, and cost a fortune to do.
Bacteria (E-Coli and faecal coliforms) were always counted on cultured plates. Viruses weren't of great interest then. The bacteria gave a good indication of waste water treatment works performance.
If I had to pick just one parameter for water quality, it would be the clarity or turbidity of the water.
Almost always, a high turbidity indicated a waste water works not operating correctly.
Turbidity is a robust measurement that can run unattended for weeks or months.
If additional measurements were needed, they would include dissolved oxygen level, temperature, pH and conductivity.
Even 30 to 40 years ago, dial-up modems were used to interrogate the data, but still required regular physical checks and calibrations.
