is there any way to communicate with arduino through the internet without shiled
Hi Everyone!
i wonder how to communicate with arduino through the internet without shiled
or maybe some way to communicate in cheap way?
I believe an ESP8266 is a cheap option for WiFi.
The cheapest is, obviously, to connect the Arduino to your PC and let the PC connect to the internet.
Tell us what you actually want to do and we can give better advice.
...R
http://www.dipmicro.com/store/ENC28J60-MINI-MOD Inexpensive way to connect.
A shield is just a convenient way of mounting electronic components. You need those extra components anyway so while you would not have a shield you would have the parts. However there are versions of the Arduino with those parts built into the board either in Wi-Fi or Ethernet capabilities.
The Ether-TEN has built-in ethernet. I don't know of any with WiFi on board but they probably exist. It will cost the same as buying an Arduino and a shield, since it's basically the identical component list either way.
