Is there any way to freeze Arduino code or 74HC595 Shift Register?
I am using a 74HC595 shift register to control a 7 segment display, and I want to make a diffuse button which will act as a button that stops the timer. Is there any way to do this?
Easily. Read the button state, if button state changes set a variable to 1 or 0, then while(variable == 1) { do nothing} .
Thanks, I’ll try it.
Remember to refresh the value in the loop or the loop will never end, so you don't actually do nothing
While ( variable == 1) variable = digitalRead(...);
