Hi, I have made a four wheeled arduino bluetooth controlled car. I have used an arduino uno, l298n motor driver, bluetooth sensor and three 3.7v li- ion rechargeable batteries along with four 3-6v dc gear motors.
The problem is that after several days of using the car, my motors eventually become slow despite using fully charged batteries and I am forced to replace them. So, instead of buying new gear motors, I only bought the motors present inside of the gearboxes (which are said to also operate at 3-6v) separately and placed them inside my existing gear boxes. I did this to reduce costs since I already possess the gearboxes and buying them along with the motors is more expensive and unnecessary.
Now, the problem is that these new motors without gear boxes consume too much current and make my l298n motordriver overheat after 2-3 minutes of using the car. The previous motors consumed less than 0.5 amps but these motors consume more than 1 amps, which really overheats my l298n motor driver and produces a burning stench, and also discharging my batteries very fast as well.
Thus, in order to reduce my current usage, I have reduced the voltage supply to the car, but then the motors simply run very slowly. Is there any other possible way to reduce the motors current usage from > 1 amps to < 0.5 amps without affecting the speed of the motor that much?
