Is there "code" for Making a Digital output NEUTRAL - NOT HIGH OR LOW - Floating OUTPUT.
Yes there is...
make it INPUT ... and it will be NEUTRAL as you want
Switch to input? That will make it tristate.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with nor for advice on your project.
Is there a way to do it within the code and still use it as an output when needed.
Like adding code in the active loop.
Sometimes I need a HIGH output, but I don't want to make it LOW to change it.
Simply make it NEUTRAL for the rest of the code and back to a OUTPUT the next time in runs.
I would like to be able to do this for each of the output pins (4 in this case).
Use pinMode().
It is allowed anywhere, not just in setup().
a7
// Sometimes I need a HIGH output
pinMode(pin, OUTPUT);
digitalWrite(pin, HIGH);
// I don't want to make it LOW to change it.
pinMode(pin, INPUT); // Simply make it NEUTRAL
// and back to a OUTPUT
What do you want to achieve?
How will the receiver read the state?
NEUTRAL will be read as either HIGH or LOW with digitalRead. But you can never know beforehand...
Yes.
This is often done when you want an open drain in a design.
See
That would make sense...
Just put a diode in series with output ? ( if you never want a “ low”)
