Is there documentation for the MegaPi PID example program or Arduino PID?
I have the Makeblock Ultimate 2.0 kit which uses the Arduino MegaPi board. There is an Arduino PID example. But, there is no explanation of what the commands are and what the numbers are. Is there a manual or tutorial of something? Thanks in advance.
The example program follows:
     * \par Copyright (C), 2012-2016, MakeBlock
     * @file    Me_Megapi_encoder_pid_speed_MAM.ino
     * @author  MakeBlock
     * @version V1.0.0
     * @date    11/27/2016
     * @brief   Description: this file is sample code for Megapi encoder motor device.
     * Function Call List:
     *    1. uint8_t MeEncoderOnBoard::getPortB(void);
     *    2. uint8_t MeEncoderOnBoard::getIntNum(void);
     *    3. void MeEncoderOnBoard::pulsePosPlus(void);
     *    4. void MeEncoderOnBoard::pulsePosMinus(void);
     *    5. void MeEncoderOnBoard::setMotorPwm(int pwm);
     *    6. double MeEncoderOnBoard::getCurrentSpeed(void);
     *    7. void MeEncoderOnBoard::setSpeedPid(float p,float i,float d);
     *    8. void MeEncoderOnBoard::setPosPid(float p,float i,float d);
     *    7. void MeEncoderOnBoard::setPosPid(float p,float i,float d);
     *    8. void MeEncoderOnBoard::setPulse(int16_t pulseValue);
     *    9. void MeEncoderOnBoard::setRatio(int16_t RatioValue);
     *    10. void MeEncoderOnBoard::runSpeed(float speed);
     *    11. void MeEncoderOnBoard::loop(void);
     * \par History:
     * <pre>
     * <Author>     <Time>        <Version>      <Descr>
     * Mark Yan     2016/07/14    1.0.0          build the new
     * MAM          10/27/2016    1.0.0          Renamed Me_Megapi_encoder_pid_speed_MAM.ino
     * </pre>
    #include <MeMegaPi.h>
    MeEncoderOnBoard Encoder_1(SLOT1);
    MeEncoderOnBoard Encoder_2(SLOT2);
    void isr_process_encoder1(void)
      if(digitalRead(Encoder_1.getPortB()) == 0)
        Encoder_1.pulsePosMinus();
        Encoder_1.pulsePosPlus();;
    void isr_process_encoder2(void)
      if(digitalRead(Encoder_2.getPortB()) == 0)
        Encoder_2.pulsePosMinus();
        Encoder_2.pulsePosPlus();
      attachInterrupt(Encoder_1.getIntNum(), isr_process_encoder1, RISING);
      attachInterrupt(Encoder_2.getIntNum(), isr_process_encoder2, RISING);
      //Set PWM 8KHz
      TCCR1A = _BV(WGM10);
      TCCR1B = _BV(CS11) | _BV(WGM12);
      TCCR2A = _BV(WGM21) | _BV(WGM20);
      TCCR2B = _BV(CS21);
      Encoder_1.setPulse(7);
      Encoder_2.setPulse(7);
      Encoder_1.setRatio(26.9);
      Encoder_2.setRatio(26.9);
      Encoder_1.setPosPid(1.8,0,1.2);
      Encoder_2.setPosPid(1.8,0,1.2);
      Encoder_1.setSpeedPid(0.18,0,0);
      Encoder_2.setSpeedPid(0.18,0,0);
      if(Serial.available())
        char a = Serial.read();
        switch(a)
          case '0':
          Encoder_1.runSpeed(0);
          Encoder_2.runSpeed(0);
          case '1':
          Encoder_1.runSpeed(100);
          Encoder_2.runSpeed(-100);
          case '2':
          Encoder_1.runSpeed(200);
          Encoder_2.runSpeed(-200);
          case '3':
          Encoder_1.runSpeed(255);
          Encoder_2.runSpeed(-255);
          case '4':
          Encoder_1.runSpeed(-100);
          Encoder_2.runSpeed(100);
          case '5':
          Encoder_1.runSpeed(-200);
          Encoder_2.runSpeed(200);
          case '6':
          Encoder_1.runSpeed(-255);
          Encoder_2.runSpeed(255);
          default:
      Encoder_1.loop();
      Encoder_2.loop();
      Serial.print(     "Speed 1:\t");
      Serial.print(Encoder_1.getCurrentSpeed());
      Serial.print("    \t Speed 2:\t");
      Serial.println(Encoder_2.getCurrentSpeed());
Looks like most of the code is documented here:
http://learn.makeblock.com/en/Makeblock-library-for-Arduino/class_me_encoder_on_board.html
