Is there interference between microsd card (SD library) and the brain library?
I have a very similar problem as this guy Data Logger Shield Gone Haywire (Arduino Brain Library) - Programming Questions - Arduino Forum ; however, it does not look like that was solved.
Project: I want to use an arduino to connect a toy eeg and log all of the data to a micro sd card. I am using the eeg from this tutorial How to Hack Toy EEGs | Frontier Nerds . It works perfectly on it's own. I am using a microSD card with a simple breakout from sparkfun SparkFun microSD Transflash Breakout - BOB-00544 - SparkFun Electronics. It also works perfectly on it's own
Problem: When I try to merge both of them together, it does not work. I have narrowed the problem down to one thing. On the eeg module, when the code calls brain.update() it returns false and not true.
BTW eeg returns a char, in my code a casted it to a string
So I think there is something in these libraries that are conflicting with each other, I am just not sure what.
Code for just the eeg (example from the library)
// Arduino Brain Library - Brain Serial Test
// Description: Grabs brain data from the serial RX pin and sends CSV out over the TX pin (Half duplex.)
// More info: https://github.com/kitschpatrol/Arduino-Brain-Library
// Author: Eric Mika, 2010 revised in 2014
#include <Brain.h>
// Set up the brain parser, pass it the hardware serial object you want to listen on.
Brain brain(Serial);
    // Start the hardware serial.
    // Expect packets about once per second.
    // The .readCSV() function returns a string (well, char*) listing the most recent brain data, in the following format:
    // "signal strength, attention, meditation, delta, theta, low alpha, high alpha, low beta, high beta, low gamma, high gamma"
    if (brain.update()) {
        Serial.println(brain.readErrors());
        Serial.println(brain.readCSV());
Code with just the SD card also just example
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * analog sensors on analog ins 0, 1, and 2
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 10;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  String dataString = "This is a test. Jacob stein ";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
Combined code, modified for debugging. It returns "the head does not work" but it successfully writes to the micro sd card.
#include <SD.h>
#include <Brain.h>
String dataToWrite;
void setup(){
  Serial.println("Initializing SD...");
  pinMode(chipSelect,OUTPUT);
  if (!SD.begin(chipSelect)){
    Serial.println("Card failed!!!");
    return;
  Serial.println("Card Initialized.");
void loop(){
     Serial.println("The Head does not work");
  File dataFile = SD.open("testtest.txt",FILE_WRITE);
  if(dataFile ){
    dataFile.println("hello");
    dataFile.close();
    Serial.print("Wrote to the SD: ");
    Serial.println("hello");
  else{
    Serial.println("Couldn't make file!!!");
delay(2000);
Earlier I had one if statement check if( brain.update() && dataFile) and then add the brain.readcsv() to the file. It wouldnt go into the body of the if statement though.
Three suggestions.
  • each time through loop() you open the sd card, but you don't close it.
  • opening the sd card each time through the loop is also going to slow down the rate of calls to brain.update().
  • You have added a delay(2000) at the end of loop which wasn't in the original brain code and which will also reduce the rate of calls to brain.update().
Pete
