Is there no internal Vref on Pro Mini Atmega 328p ?
Hello.
I’m starting to work with a Pro Mini from Deek_Robot but I’m noticing some difference from my usual Arduino Board Mega 2560.
On top of that, reading the Reference of the Pro Mini, it should be with a ATmega168. But instead, it’s a ATmega328p ???
I can’t find the Vref Pin ? Is there an internal Réfrence voltage on this ? 1.1V or 1.1V and 2.56V ? I guess, if there is, it’s not accessible from a pin like on a Mega 2560.
Then I have a Vin and a RAW. Where can I give it 5V and where can I give it 12V ? I guess the RAW is for 12 v
I want to work on car battery and I wonder if I can feed it up to 14.4V without damaging it ?
hary:
it should be with a ATmega168. But instead, it's a ATmega328p ???
Sounds like you got a "Pro Mini 328".
hary:
I can't find the Vref Pin ? Is there an internal Réfrence voltage on this ? 1.1V or 1.1V and 2.56V ? I guess, if there is, it's not accessible from a pin like on a Mega 2560.
You probably mean the "AREF" (Analog Reference) pin. The chip has one (pin 20) but it is not connected to any of the edge pins. It goes through a capacitor to ground.
hary:
The various VCC pins are for regulated 5V (or 3.3V if you have an 8 MHz model) and the RAW pin is for 7-12V. Using a higher voltage might cause the regulator to overheat. You could either use a 5V regulator and feed the board 5V through VCC or use a 7V regulator and feed the board 7V through RAW.
Yes you're right I meant AREF ! Ok so it's not accessible from the board.
Well, i have some 12V regulator, so I might use these. It won't be energy efficient but...... I'll see later to get a better solution.
Thanks for your help.
hary:
It's not brought out to an interface pin but if you need it you can solder a tiny wire to the pin or to the pin side of the capacitor.
Ok.
I don't really need AREF access all the time but I want to calibrate the 1.1V reference to make an accurate voltmeter.
When I know exactly the value of this reference, I can then use it in my code.
That's it.
Thanks for your support.
hary:
OK. Just probe pin 20 (or 17 if it uses the 28-pin version) counting counter-clockwise from the notched corner. It may be easier to follow the trace from that pin to C1 and probe there.
My 328p chip is squared, it's not a 28pin DIP package.
and AREF seams to be located at pin 20.
By the way, how is it possible Atmel make a 32pin and a 28pin package when all the 32pin are used ?
The DIP package also has 2 GND, Vcc, AVcc.
And what difference do they make between Vcc and AVcc ?
Sorry for all these questions.
hary:
The 32-pin TQFP and MLF packages have A6 and A7 pins as well as one additional GND pin (three instead of two) and one additional VCC (two instead of one).
hary:
From the datasheet: "AVCC is the supply voltage pin for the A/D Converter, PC3:0, and ADC7:6. It should be externally connected to VCC, even if the ADC is not used. If the ADC is used, it should be connected to VCC through a low-pass filter. Note that PC6..4 use digital supply voltage, VCC."
Do you mean ADC6 and ADC7 on pin 19 an 22 ?
What are these extra pin for ?
You mean Vcc instead of AVcc.
I need to dig in more the datasheet indeed !
What area in the datasheet I could find explanation concerning this ?
Till now I though the uC had only 1 A/D converter !
hary:
They are the 7th and 8th inputs to the ADC multiplexer... Two additional analog inputs.
hary:
The chip has one A/D converter with an 8-input multiplexer.
The description of the Avcc pin was section 1.1.7 of the datasheet for the ATmega48PA/88PA/168PA/328P.
I think I see.
On this 32pin package they give us access to 2 more channel of the ADC, so we have A0:A3 (PC0:PC3) (I guess they can do analog/digitalWrite as analog/digitalRead with Pull_Up resistor) and also ADC7:6 that can do only ADC readings.
So, they're using only 6/8 channel of the ADC. And not 8/8 as you mean ?
Concerning AVcc, that's the pin that give the energy to the ADC to be able to work. It's not internaly wired as I thought.
I was mistaken with AVcc and AREF !
AREF can be either externally fed from 0 to Vcc or better AVcc, or internaly connected to internal refernce 1.1V or AVcc.
Thanks very much for helping and learning describing all the uC little trick !
