is there pgm_write_data?
hey guys!
I was working on a code where I used PROGMEM storage. I can see there is a function called pgm_read_data to read data of a PROGMEM storage but since I want to store and manipulate data as well, I need to write on data too. I thought there might be a function such as pgm_write_data but apparently the PROGMEM data can only be readable! :frowning: :frowning: :frowning:
so how you guys recommend me to store big data and manipulate them?
all answers are appreciated!
thanks guys for your help
An SD card.
IIRC somewhere on here is a thread where a member created a modified bootloader that allowed you to write back to flash memory from your running sketch.
Riva: IIRC somewhere on here is a thread where a member created a modified bootloader that allowed you to write back to flash memory from your running sketch.
current Optiboot enables it https://github.com/Optiboot/optiboot/tree/master/optiboot/examples/test_dospm
but SD card is the recommended solution
a SD card adapter and the SD or SdFat library
Sd card, or maybe I2c eeprom chip. Or spi eeprom. A lot less code if you don’t need to implement a file system.
