Hello everyone:
I still don't know what is the electronic components of marking"AZt", I cannot judge it completely by the marking.
I have tried using a digital multimeter to do some tests, who can help me to continue to recognize what it is.
I switched digital multimeter to diode test option and resistance test option.
Here is what I found.
First, I use the red wire(+) connected 3 pin, the black wire(-) connected 2 pin, the voltage shows overload, the resistance shows overload. In turn, I use the red wire(+) connect 2 pin, the black wire(-) connect 3 pin, the voltage shows 0.6v, resistance shows 26M ohm.
But when I use the red wire(+) connect 1 pin, the black wire(-) connect 2 pin using diode test option.
Then, I found the voltage and the resistance values of 3 to 2 and 2 to 3 all has changed, the voltage changed to 0V, the resistance changed to 0 ohm.
But if I use the red wire(+) connect 2 pin, the black wire(-) connect 1 pin using diode test option,
the voltage and the resistance values of 3 to 2 and 2 to 3 all will go back to the start of the measured values.
At the same time, I looked at my circuit boards, I found most 1 pins seem are connected to 3.3v, 2 pins connected to SCL, SDA or maybe something else, most 3 pins are connected to 5v voltage or seems empty.
depending on Genesis92'S tips, Is this "Vdet-IC"? If it is, how do I determine the parameter is 2.2V or 3V? and PPO or ODO?
