After a sleepless night and long day struggling with this I’ve come to beg for some help. I’m honestly at wits end here. This project is almost done and I must ship it this week so I’m obviously stressing out big time here. ANY help would be more appreciated than you know.
I’ve used a handful of these waveshields http://www.adafruit.com/products/94on projects but haven’t seen this issue before. I simply want to play one of 146 sounds (named 1.wav, 2.wav, etc.) everytime a pin is triggered HIGH. I’ve done this project before (using the exact same sound files in fact). Possibly something in the new Arduino IDE has raised a bug?
This should be simple, I’m using almost stock code from an example sketch on adafruit’s website, the only real change being this line where the board waits for a HIGH trigger from another Arduino board
while(digitalRead(triggerPin)==LOW)
Serial monitor is showing a bunch of nonsense though, no file names and no sound playing when pin7 goes HIGH.
This is my sketch
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
const int triggerPin = 7; //
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the filesystem on the card
uint8_t dirLevel; // indent level for file/dir names (for prettyprinting)
dir_t dirBuf; // buffer for directory reads
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
// Function definitions (we define them here, but the code is below)
void lsR(FatReader &d);
void play(FatReader &dir);
Serial.begin(9600); // set up Serial library at 9600 bps for debugging
putstring_nl("\nWave test!"); // say we woke up!
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(freeRam());
// Set the output pins for the DAC control. This pins are defined in the library
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(7, INPUT);
// if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
if (!card.init()) { //play with 8 MHz spi (default faster!)
putstring_nl("Card init. failed!"); // Something went wrong, lets print out why
sdErrorCheck();
while(1); // then 'halt' - do nothing!
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
putstring_nl("No valid FAT partition!");
sdErrorCheck(); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(),DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
putstring_nl("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Files found:");
dirLevel = 0;
// Print out all of the files in all the directories.
lsR(root);
//////////////////////////////////// LOOP
root.rewind();
play(root);
/////////////////////////////////// HELPERS
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
* print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void)
if (!card.errorCode()) return;
putstring("\n\rSD I/O error: ");
Serial.print(card.errorCode(), HEX);
putstring(", ");
Serial.println(card.errorData(), HEX);
while(1);
* print dir_t name field. The output is 8.3 format, so like SOUND.WAV or FILENAME.DAT
void printName(dir_t &dir)
for (uint8_t i = 0; i < 11; i++) { // 8.3 format has 8+3 = 11 letters in it
if (dir.name[i] == ' ')
continue; // dont print any spaces in the name
if (i == 8)
Serial.print('.'); // after the 8th letter, place a dot
Serial.print(dir.name[i]); // print the n'th digit
if (DIR_IS_SUBDIR(dir))
Serial.print('/'); // directories get a / at the end
* list recursively - possible stack overflow if subdirectories too nested
int8_t r; // indicates the level of recursion
while ((r = d.readDir(dirBuf)) > 0) { // read the next file in the directory
// skip subdirs . and ..
if (dirBuf.name[0] == '.')
continue;
for (uint8_t i = 0; i < dirLevel; i++)
Serial.print(' '); // this is for prettyprinting, put spaces in front
printName(dirBuf); // print the name of the file we just found
Serial.println(); // and a new line
if (DIR_IS_SUBDIR(dirBuf)) { // we will recurse on any direcory
FatReader s; // make a new directory object to hold information
dirLevel += 2; // indent 2 spaces for future prints
if (s.open(vol, dirBuf))
lsR(s); // list all the files in this directory now!
dirLevel -=2; // remove the extra indentation
sdErrorCheck(); // are we doign OK?
* play recursively - possible stack overflow if subdirectories too nested
FatReader file;
while (dir.readDir(dirBuf) > 0) { // Read every file in the directory one at a time
// skip . and .. directories
continue;
Serial.println(); // clear out a new line
if (!file.open(vol, dirBuf)) { // open the file in the directory
Serial.println("file.open failed"); // something went wrong :(
while(1); // halt
if (file.isDir()) { // check if we opened a new directory
putstring("Subdir: ");
printName(dirBuf);
dirLevel += 2; // add more spaces
// play files in subdirectory
play(file); // recursive!
dirLevel -= 2;
// Aha! we found a file that isnt a directory
putstring("Playing "); printName(dirBuf); // print it out
if (!wave.create(file)) { // Figure out, is it a WAV proper?
putstring(" Not a valid WAV"); // ok skip it
Serial.println(); // Hooray it IS a WAV proper!
wave.play(); // make some noise!
while (wave.isplaying) { // playing occurs in interrupts, so we print dots in realtime
putstring(".");
delay(100);
sdErrorCheck(); // everything OK?
// if (wave.errors)Serial.println(wave.errors); // wave decoding errors
This is what serial monitor is showing every time the trigger pin goes high!
5012649.8÷
Wave test!
Free RAM: 655
Using partition 1, type is FAT16
Files found:
9512649.848265
5757.876586
84826583726912649/
83807984767312649/
8384798269458649/
86797685776912649.807673
838479826983/
67696648577012649/
80837368.6866
73786869888312649
4812649.737868
4812649.837265
4812650.737868
4812651.737868
4812650.837265
4812652.737868
4812653.737868
4812654.737868
4812655.737868
4812656.737868
4812657.737868
80698277838412649
767386694812649.837265
8384798269.6866
838479826912649.6866
74798582786512649
74798582786512650
74798582786512651
767386694812653.737868
95575712649.876586
5756.876586
95575612649.876586
5755.876586
95575512649.876586
5754.876586
95575412649.876586
5753.876586
