Is this a correct code to count the loop speed?
Hi guys!!! is this a correct code to count the loop speed?
unsigned long previousCurrentTime;
  unsigned long currentTime = micros();
  //delay (19);
  unsigned long loopSpeed = currentTime - previousCurrentTime;
  Serial.println (loopSpeed);
  previousCurrentTime = currentTime;
No.
previousCurrentTime
Lol at the name there. Bit if an oxymoron no?
As written it just gets the time between those two statements, not the whole loop.
It would be much better to measure the time for 1000 or 10,000 iterations of loop().
And make sure all the print statements are outside the timed interval.
...R
Whatever method you use it is only going to provide the speed for the loop() function containing those instructions. Change the instructions and the speed will change.
so i understand that it is correct by approach if you want to know how fast your code execute.
//loop speed counter
Robin2:
this sounds good idea.
