Is this a good budget soldering iron?
Temp knob works, I have one. Set it and forget it once paired with a good solder. Nothing scientific, didn't bring out the temp gun, but it self regulates instead of just getting hotter and hotter as some people who have never owned one like to claim for no reason.
I actually have one of the cheap "Helping Hands" that I find very useful for holding certain things while soldering such as wires and components, for example a switch. I never use it for circuit boards though, for that my panavise is so much better. I took the magnifying glass off right away because it just got in my way and that soldering iron holder is idiotic. I put some shrink tube over the alligator clip jaws because they were too sharp and damaged the things they held. I haven't had any problems with the alligator clips falling off and they look just like the one at the link.
The one on the link you posted is overpriced. You can get them way cheaper on eBay if you don't mind waiting a while for China shipping: http://www.ebay.com/itm/Third-Hand-Soldering-Iron-Stand-Helping-Magnifying-Tool-OE-/122118568705
flounder: Take a look at the PanaVise. Use google to find it. Yes, it is expensive. Look at it carefully. Notice the several axes of motion. Now look for cheap clones. You may find one. But anything less than a PanaVise functionality is just a waste of money, because you will want to (or have to) throw it out in less than a year. Even a simple bench vise would be a better investment.
Would the Panavise Model 201 "Junior" work? It's sold here on Amazon.
Based on suggestions for Hakko and Weller, I was thinking of getting a Yihua 936 (Clone of the Hakko 936) as a real Hakko or Weller is a bit out of my budget. It's sold on amazon.com here and I've seen it recommended on other sites as it's only $25-30. If I buy this in combination with this solder , would it work well and would the iron last me a while?
Anyone has experience with AOYUE soldering equipment ?
For example this station.
I dip a soft bristled toothbrush in 70% isopropyl alcohol
I do the same, but use 99.9% Anhydrous isopropyl alcohol. Airdries really quick. I have a gallon bottle of this http://www.digikey.com/product-detail/en/mg-chemicals/824-500ML/473-1150-ND/2602438 that I refill a taller version of this with http://www.digikey.com/product-search/en/static-control-esd-clean-room-products/accessories/2228308?k=isopropyl and a hog hair brush, the longer bristles fit nicely over the legs of shields. http://www.digikey.com/product-detail/en/mg-chemicals/857/473-1050-ND/949492
Does smell like a doctor's/vet's office afterwards.
CanadianCyanide:
Based on suggestions for Hakko and Weller, I was thinking of getting a Yihua 936 (Clone of the Hakko 936) as a real Hakko or Weller is a bit out of my budget. It’s sold on amazon.com here and I’ve seen it recommended on other sites as it’s only $25-30. If I buy this in combination with this solder , would it work well and would the iron last me a while?
I believe Dave Jones did a teardown of that exact Yee-haw! (as he pronounced it) model. I believe he found that it was just a superficial clone, the interior control circuitry was different and the temperature regulation wasn’t as good. Only the appearance was copied.
Good enough I’d imagine, and it has a proper iron holder.
Watcher: Anyone has experience with AOYUE soldering equipment ?
I've used an Aoyue rework station a bit. My main iron is a Weller WESD51 soldering station with digital temp control.
I bought one of these to evaluate it as a beginner iron for OlyMEGA:
https://www.amazon.com/gp/product/B013JM4AW4/ref=oh_aui_search_detailpage
I also bought a pack of Hakko tips. This iron is NOT compatible with Hakko tips.
I will be doing a video of it.
This is the best iron out there but beyond both my budget
and I’m sure the OP’s.
The Metcal is just about the absolute best I’ve seen anywhere.
It has almost zero thermal inertia and can go from single IC
pin to 16 gauge wire on a ground plain without a hint of delay.
I have an old Weller with fixed temperature tips. It works fine
for me.
Dwight
This is the best iron out there but beyond both my budget and I'm sure the OP's.
Which iron are you referring to dwightthinker ?
Watcher:
Any of the Metcal irons With the rf generator.
Dwight
People give great recommendations for great products when they're not spending their own money.
It's just an iron. A piece of hot metal. There are even ones that just use fire. Get the one you posted originally, come back when it somehow isn't doing what you want it to do.
INTP: People give great recommendations for great products when they're not spending their own money.
It is clear you have never used an soldering iron, more than casually. Have you ever remove 100 parts from a PC board without damaging a single pad ( including single sided )? The right iron for the right job. If all you want is a wood burner, it is no issue. Dwight
dwightthinker: It is clear you have never used an soldering iron, more than casually. Have you ever remove 100 parts from a PC board without damaging a single pad ( including single sided )? The right iron for the right job. If all you want is a wood burner, it is no issue. Dwight
Somehow I'm the only one that read the first words of the thread, "So I'm an Arduino beginner...." and didn't jump to conclusions of "man this guy probably needs to remove 100 parts from a PC board without damaging a single pad blah blah"
It is clear you have never acknowledged that not everyone has the same needs. Spare the ad hominem and move along. The amount that I solder has zilch to do with giving the OP advice as per his needs and budget.
I agree that it's not necessary for a beginner to get a professional soldering iron and there are some cheap soldering irons that should work fine for most any casual use. However, it is worth a bit of effort to try to get a reasonably usable iron since it is a very important tool. When I first got into Arduino I knew I would need a "good" soldering iron because I had previously a lot of trouble trying to solder with the non-adjustable hardware store model I already owned. I had no clue what constituted a good iron other than adjustability and searching for information usually led me to threads with electrical engineers fan-boying on their high end irons and saying everything in my budget was complete junk. So I decided to trust Adafruit when they said:
This 'pen-style' soldering iron is just about the best entry-level tool I've seen.
In the description of this item: https://www.adafruit.com/products/180 Well "Lady Ada" must had been high on flux fumes because the cord on this stupid thing is so stiff it's almost unusable. Also, there's no clear documentation on tip compatibility and Adafruit doesn't sell replacement tips for it. The iron does work but I've had to hang it from the ceiling by the cord and it's still very awkward constantly fighting the cord when trying to do precision work or long jobs. I can't really justify buying another one when I have a working iron since it's just a hobby for me but I really wish I had done a bit more research and spent a little more to get something that would have served me better over the years. Since I didn't pay much for it(though they do charge a good bit for shipping), it's not really worth the effort to try to splice a better cord on there.
pert: ...the cord on this stupid thing is so stiff it's almost unusable.
Yep, a big problem (and dangerous) in colder climates. I have a Chinese rework station with the same "feature". Weller stations (have?) had super flexible silicone cords. Leo..
Wawa: Yep, a big problem (and dangerous) in colder climates. I have a Chinese rework station with the same "feature". Weller stations (have?) had super flexible silicone cords. Leo..
And the super flexible cords also have problems. Some assemblers whip the cords around to get them out of their way and one of the 3 wires in the cord eventually breaks. When my company way young, I used to disassemble the irons and shorten the cords so they would work again. After two times, the cords were too short.
The really tiny wands have the same cords, but are not fixable by shortening the cords.
The problem becomes bad when the plastic strain relief gets brittle and brakes, leaving sharp edges.
now we just order new wands.
Paul
I don't think a hobbyist needs a $500 soldering iron. It is just that using a worthless iron will make you think there is something wrong with you when it is the iron that is the issue. On ebay I just saw an older TC201/TC202 that is complete( without sponge ) for $59. I have one of these and other than the pain to change tips when hot, it is a great iron. Getting a selection of three tips, will make soldering a joy. Dwight
I use a very cheap soldering iron, cost me not more than $5 (300 Indian Rs). People might laugh at me but It does my job well till now. I dont solder stuffs on a daily basis. So I think for a beginner starting with a low cost soldering iron is not an issue, once the person feels more advanced soldering requirements and can spend money later for a soldering station.
Below is a PCB I designed (manufactured by third party) and soldered yesterday.|500x375
Showing the wrong side if you have a point about soldering :)
