Well I can choose to use port manipulation or just digitalWrite(), I used it becuase I think it saves space and is easier for me to call it later in the code since I use those LEDS in lots of different places and for different modules. So instead of turning each LED off with digitalwrite(), I can just doPORD = LEDS_OFF, etc...
As for this arrayCounter1 = (arrayCounter1 + 1) % 8; Im not really sure what that does. Is it the same as what I had and only goes up to 8 then resets to 0?
The full project has lots of different Modules and Im using an Arduino nano, an ESP826 That communicate over a webpage, to control a Accelerometer, an RGB, 6 LEDS and a 7 seg display that is using a serial bus.
Here is the full code for the Arduino Side if youre interested.
//TASK LIST
//1. Resource Manager Finite State Machine (FSM)
//2. A multi-functional traffic lights controller
//3. Barrier crossing controller
//4. Motor racing lights controller
//5. A 3-colour LED controller [DONE]
//6. Two switch-debounce modules [DONE]
//7. A heartbeat module [DONE]
//8. A Tilt-Sensor and Thermometer based on the MPU6050
//9. A simple Command Interpreter
//10. Scheduler(s)
#include <Wire.h>
const byte Characters[] = {
0b01100000, //1 0
0b11011010, //2 1
0b00111110, //B 2
0b10011110, //E 3
0b10001110, //F 4
0b00000001, //DP 5
0b00011110, //t 6
0b01111100, //U 7
0b00011100, //L 8
0b10000100, //I 9
0b00000110, //R 10
0b00000000 //OFF 11
unsigned long currentTime;
byte SegDSPL;
//==============================RGB FADE LEDS=====================================
#define RED 9
#define BLUE 10
#define GREEN 11
int color = 8;
int i = 0;
bool fade = false;
//====================================SW1 MODULE (MODE SELECT)====================================//
unsigned long SW1_LastDT = 0;
int SW1, SW1_State, SW1_lastState = 1, SW1flickState = 0;
int Module = 0;
int Mode = 0;
int Trains = 0;
#define button1 A0
void switchTwo() {
SW1 = digitalRead(A0);
//unsigned long currentTime = millis();
if (SW1 == LOW) {
SW1_State = 0; // Replicating digitalRead() function.
else {
SW1_State = 1;
if (SW1_State != SW1flickState) {
// reset the debouncing timer
SW1_LastDT = millis();
// save the the last flickerable state
SW1flickState = SW1_State;
// Checks that the apporriate time has passed, basically a delay();
if (((long)(currentTime - SW1_LastDT) >= 300)) {
if (SW1_lastState == 1 && SW1_State == 0) {
Mode = Mode + 1;
Trains = Trains + 1;
SW1_lastState = SW1_State;
//====================================SW2 MODULE (MODULE SELECT)==================================//
unsigned long SW2_LastDT = 0;
int SW2, SW2_State, SW2_lastState = 1, SW2flickState = 0;
#define button2 A1
void switchOne() {
SW2 = digitalRead(A1);
if (SW2 == LOW) {
SW2_State = 0; // Replicating digitalRead() function.
else {
SW2_State = 1;
if (SW2_State != SW2flickState) {
SW2_LastDT = millis();
SW2flickState = SW2_State;
if (((long)(currentTime - SW2_LastDT) >= 300)) {
if (SW2_lastState == 1 && SW2_State == 0) {
Module = Module + 1;
Trains = Trains - 1;
SW2_lastState = SW2_State;
//===================================FSM MODULE===================================================//
#define GRANTED A2
#define GRANTED_H pinMode(GRANTED,INPUT_PULLUP);
#define GRANTED_L digitalWrite(GRANTED,LOW); pinMode(GRANTED,OUTPUT);
// State definitions
#define NoTriggerNoDemand 0 // idle state
#define TriggerIamMaster 1 // we are master after a successful claim
#define IamSlave 2 // we are slave after other device has made a successful claim
bool ACCEL = false;
bool TRIGGER;
int STATE;
int timingState, Counter;
char data, response;
unsigned long lastTime, lastTime_1 = 0;
//unsigned long currentTime;
void leaveHigh(unsigned char pin) {
pinMode(pin, INPUT_PULLUP);
void pullLow(unsigned char pin) {
digitalWrite(pin, LOW);
pinMode(pin, OUTPUT);
bool demandREQ() {
return (!(analogRead(A6) >> 8));
// function that executes whenever data is requested from master
void requestEvent() {
Wire.write("ACK"); /*send string on request */
void receiveEvent(int howMany) {
while (0 < Wire.available()) {
data = Wire.read(); /* receive byte as a character */
//Serial.print(data); /* print the character */
//Serial.println(); /* to newline */
void FSM() {
switch (STATE) {
case NoTriggerNoDemand: //No trigger, No demand
GRANTED_H;
if (TRIGGER == true) {
STATE = 1;
else if (!TRIGGER && demandREQ()) {
STATE = 2;
case TriggerIamMaster: // I am master
GRANTED_H;
if (TRIGGER == false) {
STATE = 0;
case IamSlave: // I am Slave
GRANTED_L;
if (!demandREQ()) {
STATE = 0;
if (((long)(currentTime - lastTime_1)) >= 1) {
TimerModule();
lastTime_1 = currentTime;
void TimerModule() {
switch (timingState) {
case 0:
timingState = 1;
lastTime = millis();
case 1:
if (((long)(currentTime - lastTime)) > 17) {
TRIGGER = true;
timingState = 2;
else {
timingState = 1;
case 2:
if (STATE == TriggerIamMaster) { //State 1 is MASTER state
timingState = 3;
else {
timingState = 2;
case 3:
receiveEvent(1);
TRIGGER = false;
timingState = 0;
//===================================HEARTBEAT MODULE=============================================//
unsigned long HB_LastTime = 0;
byte DP_ON_OFF;
void HeartBeatMod() {
if (((long)(currentTime - HB_LastTime)) >= 500) {
DP_ON_OFF = Characters[5];
if (((long)(currentTime - HB_LastTime)) >= 1000) {
DP_ON_OFF = Characters[11];
HB_LastTime = millis();
//===================================BIT BANGING MODULE===========================================//
#define LATCH 13
#define CLOCK 12
#define DATA 8
void bitBang(unsigned char b) {
for (int a = 0; a < 8; a++) {
if ((b >> a) & (0x01)) {
digitalWrite(DATA, HIGH);
else {
digitalWrite(DATA, LOW);
digitalWrite(CLOCK, HIGH);
digitalWrite(CLOCK, LOW);
digitalWrite(LATCH, HIGH);
digitalWrite(LATCH, LOW);
//==================================RGB LIGHTS====================================================//
int RGBLastTime;
void RGB(int R, int G, int B) {
analogWrite(RED, R);
analogWrite(GREEN, G);
analogWrite(BLUE, B);
void ColorFade() {
Serial.println(i);
if (!fade) {
if (((long)(currentTime - RGBLastTime)) > 4) {
i++;
if (i == 255) {
fade = true;
RGBLastTime = millis();
if (fade) {
i--;
if (i == 0) {
fade = false;
//===================================ACCELERMOTERE MODULE=========================================//
//===================================ON OFF MODULE SORTING=========================================//
bool Equal = false, Set1 = false, Set2 = false, Maintenance = false, Crossing = false, Racing = false,
ledOFF = false, Amber = false, Blue = false, Green = false, Red = false;
void sortingModule() {
//----------------------------------- Traffic Lights ------------------------
if (data == 0x61) {
TrafficPriority(true);
Equal = true;
Set1 = Set2 = Maintenance = Crossing = Racing = false;
if (data == 0x62) {
Set1 = true;
Equal = Set2 = Maintenance = Crossing = Racing = false;
if (data == 0x63) {
Set2 = true;
Set1 = Equal = Maintenance = Crossing = Racing = false;
if (data == 0x64) {
TrafficPriority(false);
Crossing = true;
Set1 = Set2 = Maintenance = Equal = Racing = false;
if (data == 0x65) {
Maintenance = true;
Set1 = Set2 = Equal = Crossing = Racing = false;
if (data == 0x66) {
Racing = true;
Set1 = Set2 = Maintenance = Crossing = Equal = false;
//----------------------------------- RGB Lights ------------------------
if (data == 0x67) {
RGB(0, 0, 0);
Blue = Green = Red = Amber = false;
if (data == 0x68) {
Amber = true;
Blue = Green = Red = false;
if (data == 0x69) {
Blue = true;
Amber = Green = Red = false;
if (data == 0x6A) {
Green = true;
Blue = Amber = Red = false;
if (data == 0x6B) {
Red = true;
Blue = Green = Amber = false;
//====================================MULTIFUNCTIONAL TRAFFIC LIGHTS MODULES======================//
#define LEDS_OFF B00000000
#define LR B10000000//PIN7 R
#define LY B01000000//PIN6 Y
#define LG B00100000//PIN5 G
#define RG B00010000//PIN4 GG
#define RY B00001000//PIN3 YY
#define RR B00000100//PIN2 RR
int arrayCounter = 0, arrayCounter1 = 0;
unsigned long LS1, LS2, LS3;
const byte LightsSet1[] = { LY, LR, LR | LY, LG, LY, LR, LR, LR, LR };
const byte LightsSet2[] = { RY, RR, RR, RR, RR, RR, RR | RY, RG, RY };
int T_SET1[] = { 0, 2, 1, 1, 5, 1, 1, 1, 3, 1 };
int T_SET2[] = { 0, 2, 1, 1, 5, 1, 1, 1, 3, 1 };
void TrafficPriority(bool tfLights) {
if (tfLights) {
if (((long)(currentTime - LS1) > T_SET1[arrayCounter] * 1000)) {
PORTD = LightsSet1[arrayCounter] | LightsSet2[arrayCounter1];
LS1 = millis();
arrayCounter = (arrayCounter + 1);
if (arrayCounter >= 8) {
arrayCounter = 0;
if (((long)(currentTime - LS2) > T_SET2[arrayCounter1] * 1000)) {
PORTD = LightsSet2[arrayCounter1] | LightsSet1[arrayCounter];
LS2 = millis();
arrayCounter1 = (arrayCounter1 + 1);
if (arrayCounter1 == 8) {
arrayCounter1 = 0;
//--------------------------------------------------Racing Lights-------------------------------//
int racing_aCounter;
unsigned long r_lastTime;
int r_Timing[] = { 1, 1, 1, 1, r_Random , 2 , 0.5 , 0.5 };
void racingLights(){
if(Mode <= 0){
PORD = LEDS_OFF;
if(Mode == 1){
void setup() { //-----------------------------------SETUP----------------------------------------//
leaveHigh(GRANTED);
TRIGGER = false;
STATE = 0;
timingState = 0;
Wire.begin(8); /* join i2c bus with address 8 */
Wire.onReceive(receiveEvent); /* register receive event */
Wire.onRequest(requestEvent); /* register request event */
pinMode(DATA, OUTPUT);
pinMode(LATCH, OUTPUT);
pinMode(CLOCK, OUTPUT);
DDRD |= B11111100;
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(RED, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(GREEN, OUTPUT);
int T_barrierCrossing[] = { 5000, 500, 500, 500 };
const byte L_barrierCrossing[] = { LY | RY, LR | RR, LR, RR };
bool Exit = false;
unsigned long mlastTime, clastTime, cArrayCounter;
void loop() { //-----------------------------------LOOP----------------------------------------//
currentTime = millis(); // Main track of time used in all modules
FSM();
switchOne();
switchTwo();
HeartBeatMod();
bitBang(DP_ON_OFF);
sortingModule();
if (Equal) { // Equal Priority
bitBang(Characters[3] | DP_ON_OFF);
T_SET1[4] = 5;
T_SET1[8] = 3;
T_SET2[4] = 5;
T_SET2[8] = 3;
if (Set1) { // Set 1 Priority
bitBang(Characters[0] | DP_ON_OFF);
T_SET1[4] = 7;
T_SET1[8] = 7;
T_SET2[4] = 5;
T_SET2[8] = 3;
if (Set2) { // Set 2 Priority
bitBang(Characters[1] | DP_ON_OFF);
T_SET1[4] = 5;
T_SET1[8] = 3;
T_SET2[4] = 3;
T_SET2[8] = 5;
if (Maintenance) { // Maintenance Mode
bitBang(Characters[6] | DP_ON_OFF); // If maintenance mode 7SEG = t.
if (((long)(currentTime - mlastTime) >= 500)) {
PORTD = LY | RY;
if (((long)(currentTime - mlastTime) >= 1000)) {
PORTD = LEDS_OFF;
mlastTime = millis();
if (Crossing) { // Barrier Crossing
bitBang(Characters[2] | DP_ON_OFF);
if (Trains <= 0) {
PORTD = LEDS_OFF;
cArrayCounter = -1;
else if (Trains >= 1) {
PORTD = L_barrierCrossing[cArrayCounter];
if ((long)(currentTime - clastTime) >= T_barrierCrossing[cArrayCounter]) {
cArrayCounter = cArrayCounter + 1;
clastTime = millis();
if (cArrayCounter == 4) {
cArrayCounter = 2;
if (Amber) {
ColorFade();
RGB(i, i / 10, 0);
if (Blue) {
ColorFade();
RGB(0, 0, i);
if (Green) {
ColorFade();
RGB(0, i, 0);
if (Red) {
ColorFade();
RGB(i, 0, 0);
