I'm learning Arduino. This place is great! However, I came across what might be a typo in one of the reference pages. It can be found here:
In the "Defining Digital Pins modes: INPUT, INPUT_PULLUP, and OUTPUT" section of the page, at the bottom of the "Pins Configured as INPUT" paragraph.
It reads, "If a pull-down resistor is used, the input pin will be LOW when the switch is open and HIGH when the switch is closed.
If a pull-up resistor is used, the input pin will be HIGH when the switch is open and LOW when the switch is closed."
MarcilCAD:
If you ever return to this forum, could you explain - carefully - which part of this statement concerns you?
A pull-down resistor is used when the switch connects between an input pin and Vcc (5V) - not the best way to do it actually - while a pull-up resistor is used when the switch connects between an input pin and ground, which is much safer and more practical.
