I've finally completed the setup, using some 75k, 16.5k and 33k resistors.
The multimeter displays the (almost) correct voltages (4.19v, 4.17v and 4.20v). That is related to the resistances not having the exact right impedance. But that is not a problem, it can be corrected in the program.
However, the arduino diplays the voltages with a huge error ! I've attached a screenshot, the arduino displays an average of 3.96v.
I'm using the standard reference. It is not related to the high impedances of the resistors slowing the recharge of the sampling capacitor inside the arduino, because the reading of cell1 (measured without voltage divider) is also incorrect.
I doubt it's related to the usb supply, cause it gives the exact same values when powered via 12v
Here is the (way too long & messy) code:
// the setup function runs once when you press reset or power the board
pinMode(4, OUTPUT);
pinMode(A0, INPUT);
pinMode(A2, INPUT);
pinMode(A5, INPUT);
digitalWrite(4, LOW);
// the loop function runs over and over again forever
delay(4000);
//Cell 1
int voltage1 = analogRead(A0);
float Vcell01 = voltage1 * (5.0 / 1023.0);
Serial.println(Vcell01);
if (Vcell01<3.7)
{delay(2000);
int voltage11 = analogRead(A0);
float Vcell01 = voltage11 * (5.0 / 1023.0);
if (Vcell01<3.7)
{delay(2000);
int voltage12 = analogRead(A0);
float Vcell01 = voltage12 * (5.0 / 1023.0);
if (Vcell01<3.7)
{delay(2000);
int voltage13 = analogRead(A0);
float Vcell01 = voltage13 * (5.0 / 1023.0);
if (Vcell01<3.7)
{delay(2000);
int voltage14 = analogRead(A0);
float Vcell01 = voltage14 * (5.0 / 1023.0);
if (Vcell01<3.7)digitalWrite(4, HIGH); }}}}
//Cell 2
int voltage12 = analogRead(A2);
float Vcell02 = ((voltage12 * (5.0 / 1023.0))*2)-Vcell01;
Serial.println(Vcell02);
if (Vcell02<3.7)
{delay(2000);
if (Vcell02<3.7)
{delay(2000);
if (Vcell02<3.7)
{delay(2000);
if (Vcell02<3.7)
{delay(2000);
if (Vcell02<3.7)digitalWrite(4, HIGH); }}}}
//Cell 3
int voltage123 = analogRead(A5);
float Vcell03 = ((voltage123 * (5.0 / 1023.0))*3)- (Vcell01 + Vcell02);
Serial.println(Vcell03);
if (Vcell03<3.7)
{delay(2000);
int voltage31 = analogRead(A5);
if (Vcell03<3.7)
{delay(2000);
int voltage32 = analogRead(A5);
if (Vcell03<3.7)
{delay(2000);
int voltage33 = analogRead(A5);
if (Vcell03<3.7)
{delay(2000);
int voltage34 = analogRead(A5);
if (Vcell03<3.7)digitalWrite(4, HIGH); }}}}
Can you please post a copy of your circuit for the tests you are now doing, in CAD or a picture of a hand drawn circuit in jpg, png?
Can you add Serial.println("Cell1"); and Serial.println("Cell2"); etc in your code so we know what figures we are looking at.
As an example below for Cell1. the same in your cell2 and cell3 sections.
//Cell 1
Serial.print("Cell1);
if (Vcell01<3.7)
{delay(2000);
if (Vcell01<3.7)
{delay(2000);
if (Vcell01<3.7)
{delay(2000);
if (Vcell01<3.7)
{delay(2000);
The 5.0 is not your Max input, it is what ever you calculated your max for your potential divider for the third cell junction.
Can you show your calculations for your potential dividers please.
As it looks like you can take pictures, please draw a circuit diagram by hand and post (attach) a picture of it .
Thankyou.... Tom...
(Just having first cup of java for the morning.. ahhhhhh.. )
thank you for the replies! I'll look into it tomorrow, its getting late here
Sorry if the links to the pictures were faulty.
Here they are again, this time as attachments.
is wrong, as they both give almost the same result?
Let's assume the second and third equations are wrong, then why doesn't the first give the correct result ?
I have not calculated the potential dividers, 2 of same R = voltage divided by half, one of xR and another of x/2 R and your voltage is divided by 3.
It works fine using a voltmeter so that must be right.
It's just the arduino who has an error of ~0.20v, which is huge for a lipo low voltage cutoff.
@wawa that does indeed work, but like you said if Aref ever decreases it will cause huge problems to the lipo.
Unfortunately I can't drop the voltage to 1v, it starts self-destructing below 3v
Thanks wawa !!!!
Found it, I read somewhere arduino automatically switches to the external supply when connected to usb and an external source. So I connected it to an external source and usb, because the usb voltage was 5.26v and the voltage on the 5v pin was exactly 5v when connected to the external source.
But mine does not switch to external !! so when I plugged the arduino in to the pc, the readings were incorrect.
It's all fine now and it's very precise !!
I would still be nice to make it switch to external while connected to usb to verify the measurements.
hitachi3d7:
Yes. With a minimum of 6.6volt on V-in, or a minimum of 7.3volt on the DC socket, external supply takes over.
Unless USB supply is a diode drop higher than output of the onboard 5volt regulator.
hitachi3d7:
Maybe you understood that wrong.
Use a voltage divider that drops 4.2volt to ~1volt. And 8.4volt to 1volt. And 12.6 to 1volt.
Try with e.g. 33k from first battery to analogue pin, and 10k from that analogue pin to ground.
Add this to void setup()
analogReference(INTERNAL); // use the internal 1.1volt bandgap reference
Graynomad:
That is some seriously badly written code, but not bad for your first attempt.
I disagree, that loop() function is atrocious. There should never, EVER be four closing curly braces in a row on a single line. There is no indenting at all to speak of beyond the first level.
hitachi3d7:
Holy ****, thanks tom !!! I just supposed a lipo had a chip in it that sended the voltage of each cell through a balancing cable. My bad. I'll update the code asap.
Do not assume.
Do not ever assume, especially with a dangerous component like a Li-Po battery. Samsung just recalled their new Note 7 because they messed up the battery's production process and several dozen of them caught fire while being charged overnight. I believe lithium batteries are the most delicate chemistry out there right now (at least in mass production), far more delicate than lead acid or nickle metal hydride. Do your batteries have the protection circuit built in to guard against short circuit, over voltage, or over discharging?
Don't assume, find out.
Graynomad:
And add voltage dividers.
I think some differential amplifiers will be better for this, one for each battery. You can make maximum use of the ADC's range for all of the batteries, and you don't need to do any funky arithmetic for the two on "top".
The input to the ADC should have an impedance of less than 10k. These resistors are cutting just a bit too close to that, and should probably all be about 5x lower value.
Jiggy-Ninja:
There are several tricks to fix that problem.
Reading the input twice, and using the last reading is one of them.
A 100n cap from analogue input to ground, to give the A/D a solid voltage to sample from is another one.
This post stretches that by using a 2 * 10Megohm divider. http://jeelabs.org/2013/05/16/measuring-the-battery-without-draining-it/
Leo..
I'm curious why, as I'm still learning, It should be noted however that it will never actually enter those loops under normal circumstances.
Jiggy-Ninja:
Do not assume.
I had just finished the code and ordered the lipo, of course I would've measured it before connecting it to the arduino, I'm not that dumb.
Why would I code a LVC if the battery has a protection circuit build in ?
I think some differential amplifiers will be better for this, one for each battery. You can make maximum use of the ADC's range for all of the batteries, and you don't need to do any funky arithmetic for the two on "top".The input to the ADC should have an impedance of less than 10k. These resistors are cutting just a bit too close to that, and should probably all be about 5x lower value
It works fine, and it has a huge precision, so I'll stick to this I think.
Wawa:
Maybe this could work.
Zero battery drain when not measuring.
One mosfet gate "high" at the time.
Then measure A0 with 1.1volt Aref enabled.
Leo..
Interresting, would have done this if I knew this before, now it's all finished using a 8 pin relay that will go open if the arduino detects low voltage, it does drain the battery while in use, but if it's turned off, it shouldn't.
In response to your other post, I am powering the arduino through a 12v supply, but it does not switch from usb to ext.
