Is this ATMEGA dead
Hello friends
First of all, I would like to introduce myself, I am a physician, working in medicine for 25 years, and I am not math person, so please, excuse my ignorance and be gentle on me in explaining.
I am in RC hobby, and trying to flash an ESC by BLHELI, I flashed 3 ESCs with the HobbyKing flashing tool and USBASP with no problem, the fourth identical did not work, and it gave the following error in all AVR programming GUIs and command line:
C:\BLHeliSuite13202\Interfaces\AVRDude>avrdude -p at
mega8 -c usbasp -P usb -v -U flash:r:/dev/null:i
avrdude: Version 5.11.1, compiled on Oct 16 2011 at 17:19:54
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\Khaled\Desktop\RC\ESC\BLHel
iSuite13202\Interfaces\AVRDude\avrdude.conf"
Using Port : usb
Using Programmer : usbasp
AVR Part : ATMEGA8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
W ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 90
00 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 45
00 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0
0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, USBasp - USB programmer for Atmel AVR controllers - fischl.de
avrdude: auto set sck period (because given equals null)
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
then I tried soldering directly to the pads (after checking By DMM, that they are connected to the pins according to the ATMEGA pinout diagram and 6pin connector to USABASP), I read a lot in the forums and here to try shorting JP3 in the USBASP, and I did, to no avail., the rest of the fuses thing that I understood partially don't know how to do it.
I can go ahead and buy another ESC, but it is a challenge to me and I love challenges and learning a little bit in electronics.
an somebody help....gently please
Hi, welcome to the forum.
There is not really communication between the programmer and the ATmega chip. It might be broken, or the MISO or MOSI is accidently shortcut to ground or something like that.
or perhaps MOSI & MISO are reversed, which often causes this kind of result
