is this correct??
LS,
As I writing a sketch that can use different TFT screens.
To make the used name in the code the same I wanted to use this
#define BLACK       ST7735_BLACK       // 0x0000  ///<   0,   0,   0
But the compiler reporst BLACK not found.
Any suggestions?
Harry
HWD_Colours.h (4.49 KB)
Here are the 6 first lines of your file:
#if ENABLED(ST7735)
Written by Limor Fried / Ladyada for Adafruit Industries.
MIT license, all text above must be included in any redistribution
#define NAVY        ST7735_NAVY        // 0x000F  ///<   0,   0, 123
How do you think the compiler will understand lines number 2 and 3?
Try:
#if ENABLED(ST7735)
Thanks for the suggestion but it did not work. even removing all comment produces a new eror so I included all the code
QPSK19294.zip (11.4 KB)
******** / Oops.
You’re missing this #include "HWD_Colours.h"
No it isent.{code}#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define USETFT
#if ENABLED (USETFT)
#define USETFT 1
{facepalm}
Where was the error found?
Where do you think the #include should go?
