Is this Display LCDLibrary compatible?
I'm looking at purchasing the following display: http://uk.rs-online.com/web/p/lcd-displays-alphanumeric/5326824/
It's 20x4 and driven by a KS0066U, which appears to be pin for pin compatible with the HD44780.
I think I'm fairly confident it should be OK, but I've already been bitten by buying a display with limited capability once (6100 knock-off on the breakout board - I can only get one library to work, and full screen updates take a good 5-10 seconds!).
Thanks in advance,
Mike.
"LCD driver IC KS0066U is HD44780 compatible."
"KS0066U LCD driver IC is pin for pin compatible with the HD44780. Works fine with the Arduino LiquidCrystal library without modification."
That display should work with the Liquid Crystal library.
Don
