Hi everybody,
i was just writing a hsort demo-code that should illustrate how fast a loop can run
So I wrote this version
unsigned long myCount = 1;
unsigned long StartTime;
unsigned long StopTime;
unsigned long Cnt_target = 100000000;
Serial.println("Setup-Start");
myCount = 0;
StartTime = micros();
while (myCount < Cnt_target) {
myCount++;
StopTime = micros();
Serial.print("StartTime");
Serial.println (StartTime);
Serial.print("StopTime");
Serial.println (StopTime);
Serial.print("counting up from 0 to ");
Serial.print (Cnt_target);
Serial.print( " needed ");
Serial.print(StopTime - StartTime);
Serial.println(" microseconds");
Serial.print("This means a single loop needs ");
Serial.print( (StopTime - StartTime) * 1000 / Cnt_target);
Serial.println(" nanoseconds");
which produces this output
Setup-Start
17:20:13.601 -> StartTime116
17:20:13.601 -> StopTime120
17:20:13.601 -> counting up from 0 to 100000000 needed 4 microseconds
17:20:13.601 -> This means a single loop needs 0 nanoseconds
17:20:13.601 -> StartTime6492
17:20:13.601 -> StopTime6496
17:20:13.601 -> StartTime17544
17:20:13.601 -> StopTime17544
17:20:13.601 -> counting up from 0 to 100000000 needed 0 microseconds
Huh ?! What? counting up to 10.0000.000 in just 4 µseconds?
Can I develop the next Apple-laptop? (just kidding)
after scratching my head about this result I remembered there was something about code-optimasation
The counting up is "standalone" and this might make the compiler throw it away
ANd I wrote a version that uses variable myCount before and after the while loop.
This behaves as expected.
17:23:59.527 -> Setup-Start
17:23:59.527 -> counting up myCount starts at 0
17:24:00.375 -> counting up myCount stopped at 1000000
17:24:00.375 -> StartTime116
17:24:00.375 -> StopTime818696
17:24:00.375 -> counting up from 0 to 1000000 needed 818580 microseconds
17:24:00.375 -> This means a single loop needs 818 nanoseconds
17:24:00.375 ->
17:24:00.375 ->
17:24:00.375 -> counting up myCount starts at 0
17:24:01.179 -> counting up myCount stopped at 1000000
17:24:01.179 -> StartTime827892
17:24:01.179 -> StopTime1649144
17:24:01.179 -> counting up from 0 to 1000000 needed 821252 microseconds
17:24:01.226 -> This means a single loop needs 821 nanoseconds
so is this due to code-optimisation?
best regards Stefan
