Hello guys,
I've been a passive user for some time and I learned a lot by reading your tutorials, advices, etc and I thank you so much for giving me a basic understanding about either analog and digital circuits.
But right now I'm stuck at a very simple approach and need some input.
Current project is some kind of a brightness dependant nightlight.
I've been using a LDR and a NE555 so far (analog), but I want to include some more doors and I decided to switch to using an Arduino Pro Mini.
If its dark enough the Arduino should power a Transistor as soon as a door is opened (suggestions for Transistors are very welcome, my collection is listed at the end of the post) for like 1 or 2 Minutes. Also the code shouldnt retrigger if the door was already open. The circuit is battery powered and should be low-power consuming.
My attempt so far is
//second try
int nbts = 2;
boolean btgs[2];
int bts[2];
int startpin = 2;
int ldr;
unsigned long abstand = 6000 * 10 * 10;
for (int i = 0; i < nbts; i++) bts[i] = i + startpin;
for (int i = 0; i < nbts; i++) btgs[i] = false;
for (int i = 0; i < nbts; i++) pinMode(bts[i], INPUT_PULLUP);
void buttons(int i) {
if (!btgs[i]) {
if (digitalRead(bts[i]) == LOW) {
Serial.println("im low"); //i got buttons with 3 pins, so this doesnt really matter
btgs[i] = true;
else {
if (digitalRead(bts[i]) == HIGH) {
Serial.println("im high");
btgs[i] = false;
int ldr = analogRead(A0);
delay(abstand);
else {
for (int i = 0; i < nbts; i++) {
buttons(i);
Can't test right now and wanna go on with it. Does it work? Am I stuck? How can it be more efficient?
Thanks in advance and sorry for bothering you guys, but I'm just an average enthusiast and need you professionals to proof it.
Transistors ready to be used: 2N2222, S9012, S9013, S9014, S9015, S9018, A1015, C1815, A42, A92, 2N5401, 2N5551, A733, 2N2222, C945, S8050, S8550, 2N3906, 2N390
