Is this oled display a SPI or I2C?
I just bought a new oled...I not sure is it I2C Or SPI
Given that there are probably dozens of different OLEDs and you have provided no clue to which one that you have, I do not know how we can help. I usually get the part's data sheet before I buy the part. Just sayin'.
groundFungus:
Sorry! I can't attach my photo for some reason...I asked the moderator to delete this post
See second item.
That should get you going.
Its not the most friendly forum for pictures but it does work.
Posting tips.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Guessing is not the best way to describe an issue. Actual facts are the most important.
  • Remember that the people trying to help cannot see your problem so give as much information as you can
A link to where you bought the display may be enough to help us to identify it.
I am unlikely to delete this topic.
The OP just needs to supply better information which I hope he does.
Bob.
